Skunk2 coilover with KONI yellows?
Old May 2, 2003 | 01:02 PM
DutchITR1689's Avatar
Default Skunk2 coilover with KONI yellows?
Hi, I know some of you are using Ground Controls with yellow Konis. Anyone here with ITR using the Skunk2 coilovers with Konis?
Does it fit well?
How is the quality compared to the Ground Controls? I believe the price is about the same.... Thanx.
Modified by DutchITR1689 at 11:15 PM 5/2/2003
Old May 2, 2003 | 01:09 PM
ATF Kuk's Avatar
Default Re: Skunk2 coilover with KONI yellows? (DutchITR1689)
anyone...
Old May 2, 2003 | 01:13 PM
splitime's Avatar
GCs have a special insert so they can use the Koni's without the spring base. With the skunks you may have to keep the spring cup on there, doesnt allow for as versatile adjustments.
Old May 2, 2003 | 01:18 PM
Default Re: Skunk2 coilover with KONI yellows? (splitime)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by splitime &raquo;</TD></TR><TR><TD CLASS="quote">GCs have a special insert so they can use the Koni's without the spring base. With the skunks you may have to keep the spring cup on there, doesnt allow for as versatile adjustments.</TD></TR></TABLE>
You're saying the Skunk2 has a larger diameter sleeve? Someone told me there are rings included to fit different type of shocks so you can remove the spring cup of the Konis, but leaving the snap ring (perch) on.
Modified by DutchITR1689 at 11:52 PM 5/2/2003
Old May 2, 2003 | 01:47 PM
len's Avatar
len
I just installed Skunk2s on my ITR with stock shocks. It handles a little bit better due to the lower CG, the car doesn't roll as much. It just squats in the corners.
They ride pretty comfortable, although they're not as stiff as people claim they are. They're almost like my factory system. On the freeway the car bounces due to the shocks not being matched.
I thought about getting Konis to match the system, but have decided to go with a full race setup by Zeal.
Old May 2, 2003 | 01:51 PM
Default Re: Skunk2 coilover with KONI yellows? (len)
Which springrate did you get? 10 kg/mm (559 lbs/inch) and 8 kg/mm (447 lbs/inch)?
I already have the Konis, and I want to keep them....
Old May 2, 2003 | 01:59 PM
migs's Avatar
OT: I have a set of Skunk sleeves off my GSR for $150 + shipping.
Old May 2, 2003 | 04:03 PM
JDM_ITR's Avatar
Default Re: Skunk2 coilover with KONI yellows? (Migs)
Skunk coilovers suck. period. bouncy as hell. id go with GC, they use high quality Eibach springs. Skunks springs are generic.
Old May 2, 2003 | 04:16 PM
Default Re: Skunk2 coilover with KONI yellows? (JDM_ITR)
Bouncy because of the brand? Wasn't it just because the springs were too stiff for the shocks?
Old May 2, 2003 | 05:30 PM
WiggiE's Avatar
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM_ITR &raquo;</TD></TR><TR><TD CLASS="quote">Skunk coilovers suck. period. bouncy as hell. id go with GC, they use high quality Eibach springs. Skunks springs are generic. </TD></TR></TABLE>
I was under the impression that both Skunk2 and GC used Eibach ERS springs.
Old May 2, 2003 | 06:21 PM
len's Avatar
len
Bounciness does not come from the quality of the springs. It's your struts/shocks that really controls the bounciness of your vehicle. If you have shitty shocks and you put on stiffer springs, it's going to bounce because you have....shitty shocks. Springs help control the motion of bound and rebound of the shock. But if you have shitty shocks, no matter how high quality the springs...the fact still remains... YOU HAVE SHITTY SHOCKS.
Old May 5, 2003 | 11:32 PM
ATF Kuk's Avatar
so wut would u guys suggest for shocks?
Old May 5, 2003 | 11:54 PM
dLo GSR-stolen-now-WRX's Avatar
From: kyoto sangyo daigaku, kyoto, japan, sometimes bay area CA
Default Re: Skunk2 coilover with KONI yellows? (ATF Kuk)
i have skunk2s with koni yellows, but on my GSR.
IMO, don't get skunk2 coils.
Old May 6, 2003 | 12:36 AM
2001TypeR's Avatar
I am also using the skunk2 coilovers with ITR shocks and its great, awesome handling and better traction in general. And not as bouncy as i thought it would be. The ITR shocks seem to match up well with the skunk2's.
Old May 6, 2003 | 01:30 AM
Default Re: Skunk2 coilover with KONI yellows? (dLo GSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dLo GSR &raquo;</TD></TR><TR><TD CLASS="quote">i have skunk2s with koni yellows, but on my GSR.
IMO, don't get skunk2 coils.</TD></TR></TABLE>Why not?
Old May 6, 2003 | 06:56 AM
ITR1071's Avatar
Default Re: Skunk2 coilover with KONI yellows? (2001TypeR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2001TypeR &raquo;</TD></TR><TR><TD CLASS="quote">I am also using the skunk2 coilovers with ITR shocks and its great, awesome handling and better traction in general. And not as bouncy as i thought it would be. The ITR shocks seem to match up well with the skunk2's.</TD></TR></TABLE>
I have Skunk2 on my ITR with stock shocks and it rides like ****. The car bounces all over the road. I would keep the coils, but change the struts. Koni, something, anything else but stock.
Old May 6, 2003 | 11:08 AM
Mr Hammond's Avatar
a/k/a Jomo
Default Re: Skunk2 coilover with KONI yellows? (KillaB18C5)
Anyone who complains about SKUNK2 coil-overs can usually be weeded out with two statements.
A.) They are using factory struts.
B.) There car is WAAAAY to low for any strut to handle.
What people do not realize is skunk2 uses a lot stiffer rates then off the shelf GC's. Example.
Civic: Skunk2 (roughly) 440lb/in front and 330lb/in rear.
Ground Control 200lb/in front and 180lb/in rear.
As you can see Skunk2 doubles the rates of the GC's. This is one of the reason GC is so quick to offer differnt rates for differn't applications. There off the shelfs ones are made for commfort and adjustability only. However GC's have MUCH more flexibility for spring rates where I think you can only get like 5 with Skunk2, GC's perch system is alot easier. All those double clamp systems seem to lock up after a while and one giant PITA. Anyways I would probably just get the GC's with there adapters. Call them and tell them your set-up and what you want to do and you will be set.
Old May 6, 2003 | 11:33 AM
WiggiE's Avatar
New User
Default Re: Skunk2 coilover with KONI yellows? (Mr Milano)
Can anyone verify that both GC's and Skunk2 sleeves use Eibach ERS springs??
Old May 6, 2003 | 01:22 PM
sjracer's Avatar
Default Re: Skunk2 coilover with KONI yellows? (WiggiE)
I don't know about the ITR but the quality of the Skunk2's on my DC5 Type S are real bad. I have Eibach racing springs on the way from true choice to solve my problems with the Skunk2 springs that came with their adjustable spring kit.
Read this thread i started over at clubrsx. It'll explain everything and why you shouldn't go with Skunk2 adjustable springs. Ground Control is the way to go!
Here's the link: http://forums.clubrsx.com/show...76044
Good luck with your purchase...late
Edit: I'm running on Koni Sport struts if it makes a difference.
Modified by sjracer at 11:21 PM 5/6/2003
Old May 6, 2003 | 05:42 PM
Mr Hammond's Avatar
a/k/a Jomo
Default Re: Skunk2 coilover with KONI yellows? (sjracer)
Skunk2 does not use Eibach ERS springs.
Old May 6, 2003 | 06:44 PM
JDM_ITR's Avatar
hey buddy, i have ITR shocks, and they certainly dont SUCK. and they car is not dropped too low. Skunk springs just SUCK. GC rules bc they use Eibach springs.
SKUNK SPRINGS SUCK
Old May 6, 2003 | 06:50 PM
sjracer's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM_ITR &raquo;</TD></TR><TR><TD CLASS="quote">SKUNK SPRINGS SUCK </TD></TR></TABLE>
haha did you follow the link over to my thread at clubrsx? That's the title i used for the thread. Skunk2 linear race springs fatigue an extreme amount over time. This is due to a quality issue with their springs...late
Old May 6, 2003 | 07:09 PM
Mr Hammond's Avatar
a/k/a Jomo
Well now I do not recall saying ITR struts "suck". However were they made for 550lb/in front and 440lb/in rear spring rates? No. Do you think Bilstein, Koni, KYB or Tokico struts suck? I do not, but what about if I take your precious Eibach ERS race springs and run 600/900 springs on them. They probably aren't gonna last to long or dampen these kind of spring rate with off the shelf valving. This is the first case I have personally heard with the springs Skunk2 uses. Not saying to overlook it as I'm sure Eibach is a much better spring to use as why GC has built such a reputation in the motorsports world. Anyways good luck.
Old May 6, 2003 | 07:26 PM
sjracer's Avatar
From looking at my friend's Skunk2 adjustable spring kits i can tell you this for sure:
Integra kits come with 8kg/mm (448lb/in) spring rated springs for the front and 6kg/mm (336lb/in) spring rated springs for the rear. This is also true for their RSX kit's and Civic kit's. The only difference between the 3 kits are the length of the spring.
Old May 6, 2003 | 07:31 PM
Mr Hammond's Avatar
a/k/a Jomo
Well I have two friends with Integras and both of there skunk2 kits are 10kg/mm front and 8kg/mm rear, however one of them swapped spring rates, but that doesn't matter. Spring rates still remain the same.
