Attention HID owners! Couple Questions
Old May 2, 2003 | 11:49 AM
TypeR 01 886's Avatar
Default Attention HID owners! Couple Questions
1: Did you all adjust your healight housings after installation?
And if you have adjusted, how? Did you use the "level" on the
housing or did you do it on a wall or how?
2: Does anybody have people flashing you becuase they think
you have your brights on? I get this all night... this is what made
me think that I have to adjust them down or something.
3: Also has anybody seen their own car coming down the road
from a distance? Do you know if they flicker colors similar to the S2ks?
My friend is buying an S2k and whenever he see one or sees the
headlight (distinctive) he slows down to see it. When caught up with
him on the way home he though I was an S2k with my kit? He
said that they were extremly color ful.
BTW I have trevors 4300k phillips kit. (Thanks Sam!) Entire post regarding the sale and install process.
Old May 2, 2003 | 11:53 AM
Rguy's Avatar
Voted Best Looking GDD Poster
25 Year Member
Community Builder
Community Influencer
Active Streak: 60 Days
Have same kit, never adjusted, been flickered once and i drive a lot at night. never actually seen my car coming down the road cause that would mean someone else was driving it, but they so change color somewhat. BUt not as dramatic as cars with stock HID's because of the projector lens optic differences.
Old May 2, 2003 | 11:56 AM
Chris N's Avatar
Default Re: (Rguy)
I adjusted mine, made a HUGE difference. I used my garage door as a guide adjust, then used a fence about 25 feet away when I parked on my street to make sure they were not too high. To me, it looks like I have my hi beams on, but never get any one complaining on the road.
I don't know what they look like, but i doubt they flicker like OEM HID's do.
The adjusting screws make it so easy to adjust....
Old May 2, 2003 | 12:00 PM
Dave-ROR's Avatar
Default Re: Attention HID owners! Couple Questions (TypeR 01 886)
1. yes
2. adjust them (I've never been flashed by oncoming traffic so far)
3. no
4. mine flicker where the light hits those retarded lines on the housing, I wish it didn't and I wish OEM setups didn't (they flicker for a different reason though)
Old May 2, 2003 | 12:06 PM
zer0zer0 TypeR's Avatar
Default Re: Attention HID owners! Couple Questions (dawhiteboy)
adjust them when you finish installing, you should aim them lower, and no you will not get the s2k color changing affect with a 4300K kit on a non HID housing.
HogNutz's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TypeR 01 886 &raquo;</TD></TR><TR><TD CLASS="quote">1: Did you all adjust your healight housings after installation? NOPE
housing or did you do it on a wall or how? IF I DID, I'D USE THE WALL
me think that I have to adjust them down or something. YES BUT THEY CAN DEAL WITH IT
from a distance? Do you know if they flicker colors similar to the S2ks? YEA IT LOOKS WAY AWESOME
BTW I have trevors 4300k phillips kit. (Thanks Sam!) Entire post regarding the sale and install process.</TD></TR></TABLE>
Other than that, you should be ok, because if you are putting it in then yes you need adjustment but if its just a whold ballast like ITR then you're all good.
Old May 2, 2003 | 12:11 PM
Dave-ROR's Avatar
Default Re: Attention HID owners! Couple Questions (HogNutz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HogNutz &raquo;</TD></TR><TR><TD CLASS="quote">
Other than that, you should be ok, because if you are putting it in then yes you need adjustment but if its just a whold ballast like ITR then you're all good. </TD></TR></TABLE>
what in the hell are you talking about?
edit: and if people are flashing you they are aimed too high most likely, which makes the output less effective (assuming you want to see the road ahead of you not the sky) so "they can deal with it" is about the most ignorant response I've ever read.
Old May 2, 2003 | 12:14 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dawhiteboy &raquo;</TD></TR><TR><TD CLASS="quote">
edit: and if people are flashing you they are aimed too high most likely, which makes the output less effective (assuming you want to see the road ahead of you not the sky) so "they can deal with it" is about the most ignorant response I've ever read.</TD></TR></TABLE>
:confused: too
Old May 2, 2003 | 12:19 PM
CPR's Avatar
CPR
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">1: Did you all adjust your healight housings after installation?
housing or did you do it on a wall or how? </TD></TR></TABLE>
1.) Yes, I adjusted mine in my garage. There's a section in the Helms that tells you how to do it. Basically,the car has to be ~10ft from the wall and you obviously have to be on level ground. Then you go to the wall and measure from the ground up to the cutoff and make sure it's within spec. I found it easier to turn the adjuster with a rachet/socket instead of using a screwdriver.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">2: Does anybody have people flashing you becuase they think
me think that I have to adjust them down or something.</TD></TR></TABLE>
2.) I haven't had anybody flash me yet. Sometimes I feel like it's aimed too high since the road signs seems so illuminated but I guess those are the perks of HIDs.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">3: Also has anybody seen their own car coming down the road
said that they were extremly color ful.</TD></TR></TABLE>
3.) There is slight, and I mean SLIGHT, flicker but it's nothing like the S2K. There's no color change at all but you can tell with the slight flicker that they're authentic HIDs.
Old May 2, 2003 | 12:58 PM
RiCE On IcE 2's Avatar
Default Re: Attention HID owners! Couple Questions (CPR)
is this JDM OEM HID or like aftermarket ones in a USDM or non HID JDM housing. If it's anything other then the OEM HID I don't think it will flicker. I think the lines that run though our lens (the OEM HID does not have the lines) prevent a try HID projection though it is a lot brighter
Old May 2, 2003 | 01:00 PM
Dave-ROR's Avatar
Default Re: Attention HID owners! Couple Questions (RiCE On IcE 2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RiCE On IcE 2 &raquo;</TD></TR><TR><TD CLASS="quote">is this JDM OEM HID or like aftermarket ones in a USDM or non HID JDM housing. If it's anything other then the OEM HID I don't think it will flicker. I think the lines that run though our lens (the OEM HID does not have the lines) prevent a try HID projection though it is a lot brighter</TD></TR></TABLE>
in USDM lights those lines will cause glare which produces the same color change effect that flicker has.
Old May 2, 2003 | 01:02 PM
Chris N's Avatar
from the first post of the thread:
Old May 2, 2003 | 02:08 PM
uNF$@#!'s Avatar
Bingo. "they can deal with it" is indeed the most ignorant response i've seen ever in my whole damned life. more retarded than what a dumb blonde would say.
Old May 2, 2003 | 04:53 PM
ITR00-1200
Guest
Posts: n/a
Default Re: Attention HID owners! Couple Questions (Soup ****)
Is it the housing that makes the different color flickers on OEM HIDs, or is it a combination of the output light (kelvins) and ballast that make it flicker?
Old May 2, 2003 | 04:56 PM
uNF$@#!'s Avatar
Default Re: Attention HID owners! Couple Questions (ITR00-1200)
its the cutoff point. why does no one search anymore?
Old May 2, 2003 | 04:59 PM
NeVeR bLoWn's Avatar
Check Sig if anyone wants...
Old May 2, 2003 | 05:31 PM
ITR00-1200
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Soup **** &raquo;</TD></TR><TR><TD CLASS="quote">its the cutoff point. why does no one search anymore?</TD></TR></TABLE>
Let me restate this for you Soup ****.
What is the main thing that creates the different hues WHEN it (HID) is at cutoff.
Is it the housing (bimmer housing, s2k, jags, audis, bentley, etc..) that makes the different color flickers on OEM HIDs, or is it a combination of the output light (kelvins 4.3k, 5, 6,8,9) and ballast that make it flicker differently?
Old May 2, 2003 | 05:51 PM
4-1-1's Avatar
must install my hids too see
Htounndea
Feb 24, 2007 06:45 PM
97civic123
Jan 27, 2004 08:49 PM
94DelSolVTEC
Feb 14, 2002 05:47 AM
PY2KITR1060
Nov 5, 2001 10:50 PM
