obd1 distributor on a obd0 harness will it work
Old May 2, 2003 | 11:02 AM
chirp2hrd's Avatar
Default obd1 distributor on a obd0 harness will it work
i have a jdm b16a2 its obd1 and i put the obd1 clips on the obd0 harness for the distributor will it work ??
Old May 2, 2003 | 11:17 AM
Malgerus's Avatar
Default Re: obd1 distributor on a obd0 harness will it work (chirp2hrd)
I doubt it. Can anyone verify this?
Old May 2, 2003 | 11:23 AM
Hondasaurs's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chirp2hrd &raquo;</TD></TR><TR><TD CLASS="quote">i have a jdm b16a2 its obd1 and i put the obd1 clips on the obd0 harness for the distributor will it work ?? </TD></TR></TABLE>
No. You will need an OBD1 ECU. The OBD1 does not use an injector resister box. The fuel injectors are also different.
Old May 2, 2003 | 12:16 PM
Rob!'s Avatar
Default Re: obd1 distributor on a obd0 harness will it work (ZC_CRX)
anthony get a new computer for ur piece
Old May 2, 2003 | 03:34 PM
chirp2hrd's Avatar
Default Re: obd1 distributor on a obd0 harness will it work (b16hf)
ttt will it work with obd1 clips on a obd0 harness
Old May 2, 2003 | 04:26 PM
Noahk's Avatar
No, you can not mix and match obd0 and obd1 ecus and distributors. The distributors and ECUs need to be of the same obd generation.
HondaRexBoi
Apr 20, 2021 11:52 PM
ryanangelo212
Mar 18, 2013 12:23 AM
Dkahn18
Feb 18, 2009 04:41 PM
darrenVT
Engine Management and Tuning
18
Sep 30, 2008 09:18 AM
