'94 Accord EX Head swap with H22A head !!!!!
I have already made a post about swapping a transmission from an H22A into my F22B1. It appears as though this will bolt right on. So now my next question is, if the transmission bolts right on, can I swap out the head from the H22A and put it on my F22B1 block? Any help is appreciated. Thanks!
No, it will not fit without major modification. Also, use the e=search feature located in the upper right hand corner. There was a thread about this earlier today.
BTW, Welcome to Honda-Tech
The transmission swap will probably be a good investment, but the head swap isn't. You'd spend just as much money getting it to fit and work right that you may as well buy the h22a block.
