Injector Question?
Old May 2, 2003 | 09:38 AM
Trooper's Avatar
Default Injector Question?
Ok, I know that the EG -cx has samller injectors that the eg-si. I was told that the EK dx and cx have the same size injectors, is this true? and what flow rating do they have?
Old May 2, 2003 | 09:49 AM
Kataku2K3's Avatar
Default Re: Injector Question? (Trooper)
How do you know that?? All D/B series injectors are the same and rated at 240cc... That's all I can tell ya!!
EDIT: You sure those CX injectors weren't dirty/sticking??? I guess you could send them in to be flow tested... All are 240cc tho...
Old May 2, 2003 | 09:52 AM
Trooper's Avatar
Default Re: Injector Question? (Kataku2K3)
In my eg, when i swpaed the LS in i used the cx injectors and above 4500 it would LEAN out like a ****!!! i put the LS injectors in and it was perfect!
Old May 2, 2003 | 09:56 AM
joe_bocc's Avatar
Well for sure I know that the EK cx and dx have the same injectors because they ahve the same engine.
I'm also pretty sure that all OBD 1 and later B/D series engine have the 240cc/min injectors. Perhaps your leaning problems wers due to dirty injectors not flow to their full potential.
jonesEK
Dec 17, 2010 07:27 AM
aaronhume
Apr 16, 2007 11:45 PM
da egg
Nov 6, 2006 06:45 PM
flat-blk-HB
Oct 31, 2004 02:54 PM
Tad
24
Aug 13, 2004 03:54 PM
