Brake Bias ?
Old Jul 3, 2001 | 01:49 PM
yoshi234's Avatar
I shoot brides
Default Brake Bias ?
if the car is lowered or wears stickier rubber won't the brake bias have to be adjusted accordingly?
yoshi - wh0 read the SCC article and got curious
Old Jul 3, 2001 | 02:10 PM
Big Phat R's Avatar
Default Re: Brake Bias ? (yoshi234)
Your ABS computer will take most of this into account.
If you take out the ABS then you will need a bias controller like in the Realtime cars.
Old Jul 3, 2001 | 02:14 PM
BimmerSteven's Avatar
No. Mild suspension modifications and the addition of some sticky tires on the car does NOT necessitate bias adjustment. More significant modifications and, more importantly, a change in usage of the car (heavy track time, etc) may necessitate a bias adjustment but I know plenty of guys (with ITR's and not) who never adjust the bias and remain extremely competitive.
Old Jul 3, 2001 | 02:15 PM
ZygSpeed's Avatar
Well, maybe for you guys running bigger tires out front than in the back! (just kidding, though...)
I'd say as long as the same type of changes are done (tire wise) front and rear.
Now, for those doing big brake kits and/or spoons ... (but I think Phat R pretty much got ir right wrt the ABS).
Old Jul 3, 2001 | 02:21 PM
B18C5's Avatar
I've had brake bias problems before. My rears would always lock up first. If the ABS was connected it would engage prematurely. With the sticky tires there would be MORE weight transfered to the front, so I needed to do something. Now I'm using Hawk Blues in the front with HP+ in the rear and I'm pretty happy. It would still be nice to be able to adjust though. Especially from the cockpit so you can adjust for a full or empty tank of gas. I wouldn't rely on using the ABS computer for it. It just seems to crude.
Old Jul 4, 2001 | 06:42 AM
ZygSpeed's Avatar
Default Re: Brake Bias ? (B18C5)
B18C5 -- I'm just curious, are you on the stock suspension?
B20Zer
Suspension & Brakes
Apr 13, 2018 11:20 AM
GOOKY4U
Honda Civic (2006 - 2015)
11
Nov 12, 2015 04:13 AM
Boostage
25
Jul 29, 2004 05:14 AM
EH2DX
Sep 9, 2002 09:37 AM
PiYoImuT
Jan 1, 2002 09:37 AM
