problem
Old May 2, 2003 | 07:38 AM
MysteryWagon's Avatar
Default problem
Well it looks like the b16 jumped a few teeth huge loss of power the cam gears due not line up in the center and the timming will not adjust correctly it will not let me go higher then 10degrees. is it the off camgear that is causing this? should my head be ok if it was just the exhaust cam?
Justin
actually it only looks like it jummped one tooth, so could that cause the timming to be all out of wack?
Old May 2, 2003 | 07:48 AM
Spade's Avatar
Default Re: problem (MysteryWagon)
Remove timing belt and set everything properly.
Once you have done that put the belt back on and do a compression test and a leakdown test.
Old May 2, 2003 | 08:22 AM
Default Re: problem (Spade)
yes, planning on it as soon as I finish with friends Sr20 swap and finals
Old May 2, 2003 | 01:15 PM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MysteryWagon &raquo;</TD></TR><TR><TD CLASS="quote">yes, planning on it as soon as I finish with friends Sr20 swap and finals </TD></TR></TABLE>
You might want to do it BEFORE it jumps any more teeth & bends your valves...
inline4
Dec 29, 2004 09:28 PM
pane93civhb
Nov 23, 2004 09:49 AM
Gump
Jun 4, 2004 11:18 AM
lsvtec101
Apr 27, 2004 09:45 PM
ITR #1202
Nov 22, 2003 06:52 PM
