Walbro 255 fuel pump. Overfueling?
Old May 2, 2003 | 05:40 AM
speedymon's Avatar
Default Walbro 255 fuel pump. Overfueling?
Will this give me too much fuel on a stock GSR? Or am I getting the same amount of fuel as before because fuel pressure is still stock.
Old May 2, 2003 | 06:56 AM
TGUNNER's Avatar
Default Re: Walbro 255 fuel pump. Overfueling? (speedymon)
I prety sure the High Pressure 255 will give you to much pressure, and you cant turn it down with a stock fpr.
Old May 2, 2003 | 07:06 AM
speedymon's Avatar
Default Re: Walbro 255 fuel pump. Overfueling? (TGUNNER)
Oh ok. I thought having this pump would give me more fueling capacity when i needed it. I'll check my fuel pressure and adjust it.
Old Nov 9, 2003 | 01:34 PM
speedymon's Avatar
TTT for clarification. Is 42psi fuel pressure delivering the same amount of fuel no matter if you have a 225lph hi flow or OEM fuel pump? Need to know if I'm overfueling and don't know it.
Old Nov 9, 2003 | 05:25 PM
boostsohfast's Avatar
I ran my 255 pump before my turbo setup was installed and my fuel pressure was fine and car ran good with the stock regulator.
Old Nov 10, 2003 | 04:28 AM
speedymon's Avatar
Default Re: Walbro 255 fuel pump. Overfueling? (boostsohfast)
Thanks. Anyone else?
Old Nov 10, 2003 | 04:50 AM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by speedymon &raquo;</TD></TR><TR><TD CLASS="quote">TTT for clarification. Is 42psi fuel pressure delivering the same amount of fuel no matter if you have a 225lph hi flow or OEM fuel pump? Need to know if I'm overfueling and don't know it.</TD></TR></TABLE>As long as the pressure is the same; the only thing that a high-flow pump does is pump more gasoline through the rail & back to the tank in the return line. If 225lph were enough to overwhelm the FPR, that would result in higher fuel pressure.
champLSinteg
Sep 20, 2006 04:39 PM
BoOsTiN Dc2
Feb 1, 2005 10:05 AM
Lsos
Jan 16, 2003 11:56 AM
Lei Siew Long
Jan 19, 2002 03:45 PM
