Can I convert a D16Y7 to run NON-OBD?
Old May 2, 2003 | 01:14 AM
Civicboy's Avatar
Default Can I convert a D16Y7 to run NON-OBD?
I found a 98 D16Y7 at a local yard with only 19k miles on it for $700 or a 96 with 72k for $500. Would I be able to swap the intake manifold and the dizzy and run it non OBD? I am not looking for huge power right now, just something that has low miles and a little more power then my stock D15B6.
Thanks
Old May 2, 2003 | 01:30 AM
1st-hybrid's Avatar
Default Re: Can I convert a D16Y7 to run NON-OBD? (Civicboy)
I can't really answer that for sure, but I don't see why it wouldn't work.
My question is why not just convert to obd1?
Old May 2, 2003 | 02:19 AM
jc836's Avatar
The D16Y7 is an OBD-II engine. I am sure someone has gotten it to run with a different ECU, but why bother-just get all of the harnesses and the computer and install it. I had one in my 96 HB and it ran great stock. Go for the one with genuine low miles and have fun.
Old May 2, 2003 | 02:43 AM
civickiller's Avatar
Default Re: Can I convert a D16Y7 to run NON-OBD? (jc836)
i think if u change your injectors and the dizzy to a obd0 then there shouldnt be any problem runnin a obd0 ecu. u might wanan check and make sure all the other little sensor plugs match up too. it would need to be mpfi parts, cannot use dx parts
Old May 2, 2003 | 09:34 AM
Civicboy's Avatar
Default Re: Can I convert a D16Y7 to run NON-OBD? (1st-hybrid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1st-hybrid &raquo;</TD></TR><TR><TD CLASS="quote">I can't really answer that for sure, but I don't see why it wouldn't work.
My question is why not just convert to obd1? </TD></TR></TABLE>
Then I would need to buy a different ECU, do wireing and I wanted to go as cheap as possible. At some point I may upgrade to an Si ECU and tranny. For now I just want to replace my high milage, so I will be leaving the HF ECU and tranny.
Old May 2, 2003 | 09:55 AM
Toptul_Honda's Avatar
New User
im running a OBD0 Si ECU on my d16y7, howvever i dont think i can help you out since i bought the car with the swap already in!
Old May 2, 2003 | 09:59 AM
Civicboy's Avatar
Default Re: Can I convert a D16Y7 to run NON-OBD? (G2-Rex)
Did they swap over the entire OBD0 intake mani?
Old May 2, 2003 | 10:01 AM
Malgerus's Avatar
You would need to use your OBD-O injectors, distributor, and you could use your Y7 manifold if you extend the MAP sensor wires. Make sure you get a M/T version of it, because like a D16Y8 the auto versions have a different style IACV.
Old May 2, 2003 | 10:09 AM
Civicboy's Avatar
Default Re: Can I convert a D16Y7 to run NON-OBD? (Mr. S)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr. S &raquo;</TD></TR><TR><TD CLASS="quote">You would need to use your OBD-O injectors, distributor, and you could use your Y7 manifold if you extend the MAP sensor wires. Make sure you get a M/T version of it, because like a D16Y8 the auto versions have a different style IACV.</TD></TR></TABLE>
So if it has the mani I can use it, but how do I tell if it is from a manual or stick if there is no tranny with it?
Old May 2, 2003 | 10:27 AM
Malgerus's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Civicboy &raquo;</TD></TR><TR><TD CLASS="quote">
So if it has the mani I can use it, but how do I tell if it is from a manual or stick if there is no tranny with it?</TD></TR></TABLE>
Easy.
1. Does it come with a flexplate or flywheel?
2. M/T versions have the IACV on the back of the intake manifold. Auto versions have it on the Throttle Body, and it has 1 more wire than the M/T version.
Let me get this straight though... you're paying 700 US for a sohc non-vtec? You can find a D16Y8 for cheaper than that. I paid 850 cdn for a 96 D16Y8 with a bored out throttle body, AEM cam gear, complete wiring harness. It also had 62,000 kms on it.
Old May 2, 2003 | 12:00 PM
Civicboy's Avatar
I haven't bought it yet, I'm still looking around. I just wanted to know if it would work becasue I was just looking for the lowest miles I could find and that is what I found. I don't want to convert to a Vtec motor, because then I would have to buy an ECU and do some wireing. Thanks for the info.
Old May 3, 2003 | 11:24 AM
New User
well im using the
- 91 Si Intake Manifold
- 91 Dizzy
Old May 3, 2003 | 01:59 PM
Spaceballsthelunchbox's Avatar
No Big Whoop
It's a 100% direct bolt in.
I did that exact same swap a few times already.
You just need to do a long block swap.
Keep both complete manifolds, use ALL the mounts AND brackets from your current engine, transplant the AC compressor, distributor and you are done.
Easy as heck.
the nice thing is that unlike the D16Z6. the D16Y7 head uses the same mounting holes for the distributor, so you just bolt it in.
It's the easyest, most straight forward swap you could do on a CRX or Civic (EF).
EDIT:
Just remember. there is one modification you need to do.
the D16A6 (CRXSi) uses a block mounted thermoswitch, while the D16Y7 has it on the thermostat housing. So you will need the plug for that from a 92+ civic.
Just lenghten the wires and plug it in.
Old May 3, 2003 | 03:19 PM
Civicboy's Avatar
Default Re: Can I convert a D16Y7 to run NON-OBD? (Spaceballs the lunch box)
Very cool thanks The car its going into is a HF will the thermo sensor be the same? Thanks
Modified by Civicboy at 4:29 PM 5/3/2003
hoffdaddy
Feb 15, 2015 06:35 AM
Zack Gunther
13
May 10, 2013 08:42 AM
da_rimrocka
Jan 25, 2006 04:07 PM
CRX+MaAN
21
Oct 5, 2004 06:50 PM
zexdrex
Nov 6, 2003 11:12 PM
