CTR Intake Cam Install
Old May 1, 2003 | 11:40 PM
ciRcuitJerk's Avatar
jus f0 dekarayshunZ
Default CTR Intake Cam Install
well i have a few questions. ive searched and read up a bit and i feel that i want to try this with a buddy...whats the worst that could happen right ..anyone know any other sites to help besides the c-speed site...also it says to use assembly lube and honda bond...my buddy edgar says i can use oil for the assembly lube which im probably gonna do since my engine is in use and i was just basically curious about the honda bond part???is it really necessary and why?..thanks for the help...any tips would be appreciated
Old May 1, 2003 | 11:48 PM
b19coupe's Avatar
Default Re: CTR Intake Cam Install (CiRcUiTsi)
Use just a little Hondabond HT on the corners of the valve cover gasket, eight spots in all. You can use oil as assembly lube, but there are a few people around that insist assembly lube (like ARP moly lube) is the only way to go. Just make sure to install the cam caps in the right locations, they are numbered. Torque the 12mm bolts to 19 ft/lbs. and the 10mm bolts to 8 ft/lbs.
Old May 2, 2003 | 12:02 AM
jus f0 dekarayshunZ
Default Re: CTR Intake Cam Install (b19coupe)
thanks b19...on the cspeed site it says something about using the h-bond on the cam caps i believe..whats the dilly with that
Old May 2, 2003 | 12:06 AM
b19coupe's Avatar
Some people use a little Hondabond on the cam caps at the ends to prevent oil leaks (not the middle cam caps), just a touch. And on the cam plug at the end of the exhaust cam.
Old May 2, 2003 | 12:07 AM
jus f0 dekarayshunZ
anyone have some detailed pics..actually will the helms manual tell you exactly how to do it cause im gonna be using one of those
Old May 2, 2003 | 02:23 AM
inFamousOneSix's Avatar
yes the helms manual will tell u everything u need to know, down to where to apply assembly lube and hondabond.
Old May 2, 2003 | 05:21 AM
94CivicSi's Avatar
Default Re: CTR Intake Cam Install (inFamousOneSix)
I'd use assembly lube if I was building a motor on a stand, but if you're putting this cam in a car that you're going to start up when you're done, oil is fine.
It's kinda hard to describe where the drops of Hondabond go. There's a little corner created when you put the caps on the head. It's hard for the gasket to fill that little corner. That's where it goes. You could actually use any hi-temp RTV. I got Permatex Ultra at my local auto parts store and saved some money.
Old May 2, 2003 | 05:25 AM
Xsi's Avatar
Xsi
Theres also how-to's here: http://www.g2ic.com/tegtips/en...l.doc
And here: http://tech.hybridgarage.com/tech/cams.html
Old May 2, 2003 | 07:13 AM
Audi RS4's Avatar
Lover
Default Re: (Xsi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Xsi &raquo;</TD></TR><TR><TD CLASS="quote">Theres also how-to's here: http://www.g2ic.com/tegtips/en...l.doc
And here: http://tech.hybridgarage.com/tech/cams.html</TD></TR></TABLE>
access denied...
Old May 2, 2003 | 07:45 AM
Xsi's Avatar
Xsi
Default Re: (AK1200)
They both work for me
Old May 2, 2003 | 08:00 AM
IN VTEC's Avatar
Default Re: CTR Intake Cam Install (94CivicSi)
He should be able to see where the silicone sealer goes b/c of the residue on the bottom of the (4) outer caps. Use a thin smear.
MikeKi
Mar 28, 2010 04:39 PM
JDM_EK4_Coupe
Apr 30, 2007 12:19 PM
DFW
Feb 24, 2007 05:09 PM
LOWNSLOW
May 21, 2004 08:04 AM
nfn15037
Mar 11, 2002 05:17 PM
