Tips on Install?
Old May 20, 2004 | 03:59 PM
LOWNSLOW's Avatar
Default Tips on Install?
Modified by LOWNSLOW at 7:59 AM 7/18/2004
Old May 20, 2004 | 04:39 PM
1Quikgsr's Avatar
you can use regualr oil as a lube, but when i installed mine i used thick compound,called engine assemble lube.
Old May 20, 2004 | 04:49 PM
Quiks66's Avatar
Default Re: (1Quikgsr)
Keep in mind that your engine should be bone cold before you open it up. This way you'll avoid breaking off bolts in the head when they are warm. Use Engine assembly lube available from Autozone of Pep Boys. Also remember that if you are switching camshafts, you will need to preform a valve adjustment right then and there. Running around on valves not adjusted to your new camshaft specs can do damage if you're not careful. Where in SoCal are you located? I might give you a hand if you could use it
Old May 21, 2004 | 08:04 AM
patdemps's Avatar
Default Re: Tips on Install? (2Slow2Run)
Grab a manuel, take your time and get some people to help out. More people always help. Especially since someone right above your last post offered help. I'd talk with him and use his help, especially since he knows what he is doing.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Quiks66 &raquo;</TD></TR><TR><TD CLASS="quote">Keep in mind that your engine should be bone cold before you open it up. This way you'll avoid breaking off bolts in the head when they are warm. Use Engine assembly lube available from Autozone of Pep Boys. Also remember that if you are switching camshafts, you will need to preform a valve adjustment right then and there. Running around on valves not adjusted to your new camshaft specs can do damage if you're not careful. Where in SoCal are you located? I might give you a hand if you could use it </TD></TR></TABLE>
for people that love to give out a lending hand
civic1990133
Honda Civic (2001 - 2005)
Dec 8, 2011 02:16 AM
trecool44
Nov 27, 2005 05:31 PM
importboi22
10
Mar 5, 2004 11:19 PM
