Little help: 92 VX, JDM H22, Walbro 255 lph, no fuel pressure.
Old May 1, 2003 | 11:17 PM
poison's Avatar
Default Little help: 92 VX, JDM H22, Walbro 255 lph, no fuel pressure.
I just swapped my h22 from my EX to my 92 VX. Installation and everything went well.
Little problem, however. I recently bought a Walbro 255 lph fuel pump, installed it very easily, harness plugged in and everything.
Installed the H22, and now the car will not start. I have a B&M FPR and B&M fuel pressure gauge, and I have no fuel pressure at all.
We checked all fuses, and I also switched the VX main relay to the EX relay just to make sure it wasn't the main relay (at which both click when trying to start the car).
When I put the key onto the ON switch, the fuel pump does not click.
Any suggestions?
I need to have the car up and running tomorrow for racing. Any help would be much appreciated.
Old May 1, 2003 | 11:48 PM
MPower332TI's Avatar
Default Re: Little help: 92 VX, JDM H22, Walbro 255 lph, no fuel pressure. (poison)
Yo dude pull the pump and make sure that its hooked up good an maybe even test for voltage at the plug. You can also take the pump out and hook it up to a battery and see if it runs. Or throw the stock pump back in and check it. Dude i wanna see some pics of this hatch. Let me know whats up with it.
Old May 2, 2003 | 12:35 AM
poison's Avatar
Default Re: Little help: 92 VX, JDM H22, Walbro 255 lph, no fuel pressure. (jDmDxTuRd)
yooo shawn!
As you posted this I put in the stock EX fuel pump (gave the VX to a friend) with no changes, and hooked it up to the plug, put the key on the ON switch, and still same result with no noise from the fuel pump or fuel pressure
I have pics now, just have to take some more
It should be up and running tomorrow and completely done if I can get this damn thing out of the way lol.
Old May 2, 2003 | 07:34 AM
poison's Avatar
bizump for day time.
b1829
Jul 26, 2007 02:17 PM
morrist
Aug 19, 2005 07:00 AM
bigbacon2
Jul 31, 2005 05:34 PM
92acclude
Jan 31, 2005 05:33 AM
poison
21
May 2, 2003 06:26 PM
