cluster & mpfi swap question
Old May 1, 2003 | 08:46 PM
-16V-'s Avatar
Default cluster & mpfi swap question
ok, I know when swapping clusters you can use a civic or crx same year right? Now what about using a 91 four door civic cluster with tach in my 91 hatch. Will it fit?
And about the mpfi swap. I was told wene doing that swap to use the same year si harness with DIZZY???? Do need to swap dizzy to?
Or can i just add the four wire's to my dx harness?
Old May 1, 2003 | 11:25 PM
88rexdxa6ed's Avatar
Default Re: cluster & mpfi swap question (1991_jdm_sleeper)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1991_jdm_sleeper &raquo;</TD></TR><TR><TD CLASS="quote">ok, I know when swapping clusters you can use a civic or crx same year right? Now what about using a 91 four door civic cluster with tach in my 91 hatch. Will it fit?
Or can i just add the four wire's to my dx harness?</TD></TR></TABLE>
somebody answer this question i need to know too
Old May 2, 2003 | 12:03 AM
Malgerus's Avatar
Default Re: cluster & mpfi swap question (88rexdx)
88-89, 90-91 civic/crx guage clusters are interchangable, as long as you stay within the two years. Doesn't matter if it's from a 4 dr ex or CRX Si, just as long as the years match up.
You NEED the Si/hf Distributor, because it has a sensor (I think crank angle sensor) that the DPFI distributors don't have.
FastAsleep
Sep 1, 2006 06:41 PM
SLR ef9
Apr 24, 2006 06:22 PM
Deviation
18
Apr 15, 2006 06:35 PM
KarbinFourteen
10
Oct 19, 2004 01:44 PM
acuratech
Jun 26, 2003 11:05 PM
