Anyone need some Infiniti Kappa's 6.5''?
Old May 1, 2003 | 08:22 PM
haloseven's Avatar
Default Anyone need some Infiniti Kappa's 6.5''?
i bought these for my civic, but sold it, so these speakers wont switch over to my Subie. These are BRAND NEW With a 1 year warranty via IKESOUND.COM - i need 4''ers for the subie. paid $85 from ikesound, will sell for 75 shipped (pretty big) they wont fit in the doors w/o a spacer, but these are great for the rear deck of any honda. these things fuggin bump.
here's the description
450watt INFINITY KAPPA 62.5i 6-1/2" 2-way
(New release to 2002)
List Price: $170
Pair 450 watt Infinity Kappa 62.5i 6-1/2" 2-way Speakers
Oversized C.M.M.D. woofer with hi-roll rubber surrounds
o pivoting C.M.M.D. balanced dome tweeter
o 2-75W RMS power range
peak power handling 450 watts (225 each)
Detailed Features
Ceramic Metal Matrix Diaphragm (C.M.M.D.): Infinity's C.M.M.D. technology delivers accurate performance with dramatically reduced distortion for incredibly lifelike sound. Additionally, the C.M.M.D. drivers can withstand extreme temperatures, moisture, humidity and sunlight.
C.M.M.D. Plus One Woofer Cones: These speakers use cones approximately 30% larger than other speakers of the same size. This is accomplished by using a new basket design and hi-roll surround. The Plus One design offers greater bass output and a significant increase in efficiency. In addition, the C.M.M.D. cones virtually eliminate coloration due to cone flexing, resulting in less distortion and superior accuracy.
Surrounds: The hi-roll rubber surrounds allow the woofers a greater range of movement, resulting in longer X-max and more bass output.
UniPivot C.M.M.D. Dome Tweeters: Each speaker has a 1" C.M.M.D. dome tweeter that offers superior stiffness and damping compared to traditional metal domes. The UniPivot tweeter is angled (non-adjustable) and may be turned up to 355 degrees for optimum imaging and in-car frequency response. It is not made to turn 360 degrees. If the tweeter is turned 360 degrees or more, it will be damaged.
2-Way Crossovers: These speakers include computer-optimized, voice-matched crossovers. Each crossover features an 18dB/octave, 3.5kHz high-pass network for the tweeter and an 18dB/octave, 3.5kHz low-pass network for the woofer.
Crossover Connections: Each crossover has an 11" input lead terminated with bare wire and two 18" output leads, one for the woofer and one for the tweeter, terminated with female quick-slides. The positive woofer lead has a 0.205" female quick-slide and the negative woofer lead has a 0.110" female quick-slide. The positive tweeter lead has a 0.250" female quick-slide and the negative tweeter lead has a 0.187" female quick-slide. These quick-slides connect directly to the woofer and tweeter terminals on each speaker.
Crossover Dimensions: L=3.458", W=1.734", H=1.087"
Adapter Rings: These speakers come with three different mounting adapters. The adapters allow the speakers to be installed in a 6-1/2" opening, a 6-3/4" opening, or an oversized 6-3/4" GM/Chrysler opening.
Old May 2, 2003 | 04:51 PM
lucas569's Avatar
Default Re: Anyone need some Infiniti Kappa's 6.5''? (haloseven)
sold!!! i just sent u pm
Old May 2, 2003 | 05:39 PM
Broman78's Avatar
Default Re: Anyone need some Infiniti Kappa's 6.5''? (lucas569)
if he falls thru i will buy the speakers.
'Accord Ex'
Audio / Security / Video
Aug 12, 2007 09:37 PM
x3kevin
Nov 22, 2006 06:25 PM
7808
Jul 30, 2004 02:41 PM
Mr Boston
Sep 26, 2003 11:18 AM
shattergsr
Jun 6, 2002 02:08 PM
