jrsc'd b18b1 with jg cams....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Speed PHreak »</TD></TR><TR><TD CLASS="quote">Nope, mine is the only one that matters.</TD></TR></TABLE>
I wouldn't trust anyone whose CRX traps 120 mph on an LS platform spinning all the way down the track. Just avoid the Type-R cams like the other poster suggested, it's best to run auto B16A1 cams with high mileage worn down lobes if you can find them.
Even though there hasn't been much testing done with this, anyone who has worked with positive displacement blowers will tell you that they take very well to cams with a slightly higher lift but longer duration than the stock ones. They also do not like overlap.
Unless you have money to test out different cams, go with a set of adjustable cam gears and dial out your overlap. The next option is to add the M62 blower to your setup. The gains will be much higher with an M62, than if you were to run the M45 and cams.
They are pretty cheap. Most of the M62's off of Mercs and GMs I see go for $150-250. Nobody wants the hassle of having to fab a belt drive system, so they get ignored.
They are more fluent in domestic circles... hint hint.
where do you see the blowers for that price?
i have adj cam gears already. so with my stock cams, should i advance the intake cam and retard the exhuast cam?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by J. Davis »</TD></TR><TR><TD CLASS="quote">They are pretty cheap. Most of the M62's off of Mercs and GMs I see go for $150-250. Nobody wants the hassle of having to fab a belt drive system, so they get ignored.
They are more fluent in domestic circles... hint hint.</TD></TR></TABLE>
Yeah but I thought that we couldn't use those. I had heard that the ones made for our honda engines had to spin in the opposite direction as the rest of the car world?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JASON77 »</TD></TR><TR><TD CLASS="quote">
thats what i've heard as well. its part of the reason that we cant upgrade to the M90 (besides the clearance issues). something about moss motors (jackson racing) holds the patent or the rights to the opposite-spinning direction.
That is correct information on the M62 for the Hondas being counter-rotating.
I also encourage you to try different cam setups until you find for yourself what works. If you are a hybrid with VTEC head try the GSR intake and Type R exhaust, worked really well for me engaging VTEC at 2800rpm.
Good luck.
Good luck.
