Head pics, deshrouding th valves
Old May 1, 2003 | 06:07 PM
satan_srv's Avatar
Default Head pics, deshrouding th valves
Got some head pics from Top Power Racing. The Pics show deshrouding of the valves, a technique that allows for better breathing in the head. Maybe someone has some good links to info on deshrouding, but it's a good power making technique, good for high lift/duration cams
To quote Dirtylude, "All deshrouding really means is cutting away the little skirt area that comes on the head around the valves and taking away some material around where the valves meet the edge of the chamber. On a stock head the top of the chamber would be perfectly circular, on those above you can see where they've cut out some material around the valves. I assume you're running larger then 87mm pistons. Since the bore will be bigger you have more room to cut out material around this edge of the valves, which is what they did. "
I am running 89mm pistons, so from the pics you can see how the valves now sort of 'stick out' of the 87mm chamber bore, they have been deshrouded to the full 89mm Now this is a power maker
Old May 1, 2003 | 06:19 PM
Prelude Vtec 23's Avatar
Default Re: Head pics, deshrouding th valves (satan_srv)
nice pics
Old May 1, 2003 | 07:35 PM
Sticky Tires's Avatar
* B A N N E D *
Default Re: Head pics, deshrouding th valves (Prelude Vtec 23)
nice & clean
Old May 1, 2003 | 08:34 PM
Elkins911's Avatar
Default Re: Head pics, deshrouding th valves (Sticky Tires)
damn... sometimes i wish my feet looked as good as your engine.
Old May 1, 2003 | 08:35 PM
Boostless97Lude
Guest
Posts: n/a
Default Re: Head pics, deshrouding th valves (Elkins911)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Elkins911 &raquo;</TD></TR><TR><TD CLASS="quote">damn... sometimes i wish my feet looked as good as your engine.</TD></TR></TABLE>
um.......
Old May 1, 2003 | 09:05 PM
GODluvsLUDES's Avatar
Toenail clippers and tinactin tends to help fyi
Old May 2, 2003 | 03:53 AM
satan_srv's Avatar
eww!
Old May 2, 2003 | 08:55 AM
flyrod's Avatar
Thanks for posting the pics
Old May 2, 2003 | 11:19 AM
CHK4TIX's Avatar
Default Re: Head pics, deshrouding th valves (flyrod)
that looks great, the only problem i can see is that i dont have enough money to get it done to mine.
Old May 2, 2003 | 06:05 PM
satan_srv's Avatar
Default Re: Head pics, deshrouding th valves (CHK4TIX)
well on a stock head you would only see gains mildly dessrouding..nothing crazy like this..
Old May 2, 2003 | 07:37 PM
CBR's Avatar
CBR
So this deshrouding process will lower compression, right?
Old May 2, 2003 | 08:08 PM
satan_srv's Avatar
Default Re: Head pics, deshrouding th valves (ChurchBoyRacer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ChurchBoyRacer &raquo;</TD></TR><TR><TD CLASS="quote">So this deshrouding process will lower compression, right?</TD></TR></TABLE>
well it would have, had we not milled the head a little to get it back.
This isn't a TON of material, but yes if you did nothing it would lower compression.
Old May 2, 2003 | 08:23 PM
BoostedH23a1's Avatar
milling the head brings comp ratio up..
Old May 2, 2003 | 08:57 PM
CBR's Avatar
CBR
Default Re: Head pics, deshrouding th valves (BoostedH23a1)
Is there a rule of thumb to how much you can mill off a cylinder head before it becomes useless?
Old May 2, 2003 | 09:18 PM
prelude1897's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Prelude Vtec 23 &raquo;</TD></TR><TR><TD CLASS="quote">nice pics </TD></TR></TABLE>
Old May 4, 2003 | 07:16 AM
satan_srv's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ChurchBoyRacer &raquo;</TD></TR><TR><TD CLASS="quote">Is there a rule of thumb to how much you can mill off a cylinder head before it becomes useless? </TD></TR></TABLE>
I haven't heard of anyone going over 30 thousandths
Old May 4, 2003 | 07:27 AM
my roomates was 60 thousandths over...
thats gude for yea
Old May 4, 2003 | 09:51 AM
Tuney's Avatar
what valves are you using?
Old May 4, 2003 | 10:08 AM
satan_srv's Avatar
Default Re: Head pics, deshrouding th valves (Tuney)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tuney &raquo;</TD></TR><TR><TD CLASS="quote">what valves are you using?</TD></TR></TABLE>
stock
H-allmotorda9
17
Feb 6, 2010 07:40 PM
AntMan401
Mar 17, 2008 02:13 PM
Jeter2NYC
Jun 15, 2006 06:44 PM
satan_srv
May 2, 2003 05:51 PM
