BEST way to drill a hole in the fire wall....and What oil do you use?
Old May 1, 2003 | 05:25 PM
GreenMachineRex's Avatar
Default BEST way to drill a hole in the fire wall....and What oil do you use?
i have my lines for my gauges running threw my hood release thing, but i want to drill a hole in my fire wall so i won't need 30000ft of wire...don't ask i just want to
should i just get a drill and drill away or what? my one friend messed up his intake manifold trying to drill a hole.....
and what oil do u use in the summer?
Old May 1, 2003 | 05:28 PM
incubus's Avatar
Default Re: BEST way to drill a hole in the fire wall....and What oil do you use? (GreenMachineRex)
Have a friend watch the other side of the firewall while you drill, make sure your path is free of wires n such before starting to drill.
Old May 1, 2003 | 06:20 PM
civbeater90's Avatar
Default Re: BEST way to drill a hole in the fire wall....and What oil do you use? (incubus)
go to a hardware store an dbuy grommets also.this way no rain gets inside
Old May 1, 2003 | 06:21 PM
matt j's Avatar
there should be a rubber grommet on the passenger side about half way down on the fire wall, if thats not there just follow the engine harness to the firewall, poke a hole in the grommet and run the wires through there.
i run mobil 1 synthetic 10w30 all year round (i live in cali)
Muckman
Welding / Fabrication
12
Apr 11, 2008 09:50 AM
-DesTiNy-
59
Apr 18, 2006 11:17 AM
ineedhelp
10
Feb 4, 2006 06:44 AM
Mr. Samurai
Feb 26, 2005 09:48 PM
integranator
Apr 14, 2003 10:41 PM
