Squeeky brake pads...
Old May 1, 2003 | 04:20 PM
Ninja Mike's Avatar
Default Squeeky brake pads...
I was wondering if i could spray the rotor with Gunks's disc brake quiet spray?
The directions say to spray the pads but i didn't have any luck taking the pads out (couldn't get the bolts off, may I need an air-wrench?) -i am an amateur.
Old May 2, 2003 | 09:43 AM
Aron Parsons's Avatar
Default Re: Squeeky brake pads... (MikeBSI)
The disc brake quiet spray is an adhesive used to keep the pads in place on the caliper. DO NOT SPRAY ON THE ROTORS! If you can get the bolts broken free (try a breaker bar), getting the pads out is simple. Put the spray on the back of them. Also, a good cleaning of the rotors and pads with brake cleaner can do wonders as well. It's really not hard, just give it a go.
Old May 2, 2003 | 12:09 PM
psi420's Avatar
Default Re: Squeeky brake pads... (Aron Parsons)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Aron Parsons &raquo;</TD></TR><TR><TD CLASS="quote">The disc brake quiet spray is an adhesive used to keep the pads in place on the caliper. DO NOT SPRAY ON THE ROTORS! If you can get the bolts broken free (try a breaker bar), getting the pads out is simple. Put the spray on the back of them. Also, a good cleaning of the rotors and pads with brake cleaner can do wonders as well. It's really not hard, just give it a go.
You need a breaker bar for 12mm bolts?
Old May 2, 2003 | 01:59 PM
yaya's Avatar
Default Re: Squeeky brake pads... (psi420)
put that gunk betweet the metal slips and the pads
i didnt and my brakes squeak too sometimes
h
TailZ
Honda Civic (2001 - 2005)
Oct 13, 2008 01:57 PM
crx00
Apr 4, 2006 08:38 PM
jaealdana
16
Jul 29, 2005 01:50 PM
apexinghonda
45
May 27, 2004 07:02 PM
