upgrading my t3/t4, suggestions?
Old May 1, 2003 | 03:31 PM
egg's Avatar
egg
Default upgrading my t3/t4, suggestions?
right now i have a T3/T4 turbo, .82 ar exhaust, .60 ar 60 trim intake. my plans are to hit over 400 HP with a 8k rpm redline. what are your suggestions on a turbo upgrade? budget is kinda tight.
Old May 1, 2003 | 05:40 PM
SpoolnG2's Avatar
Default Re: upgrading my t3/t4, suggestions? (egg)
that turbo will get you over 400hp. all u gotta do is turn up the boost and get it tuned. what motor setup are u runnin?
Old May 1, 2003 | 05:44 PM
RyanAutry's Avatar
Precision SC44 .60/.63
Since you're on a budget, talk to Arturbo.
Old May 1, 2003 | 09:28 PM
egg's Avatar
egg
sorry i shouldve been a little more specific. i wanted over 400 hp, in the 500 hp range. the suggestion about the SC44, wouldnt that be a step down? my turbo is .82 ar/.60 ar. sorry if i am wrong, i am not completely knowledgable about turbos
Old May 1, 2003 | 09:30 PM
Gravy's Avatar
anything that precision builds is never a step down!!!
Old May 1, 2003 | 09:54 PM
SpoolnG2's Avatar
Default Re: upgrading my t3/t4, suggestions? (GRTechnologies)
what size wheel do u have in your turbo right now? stage 3 or 5?
Old May 1, 2003 | 09:56 PM
TurboDANDEE's Avatar
Default Re: upgrading my t3/t4, suggestions? (SpoolnG2)
.82 a/r is huge for a street car
pics?
Old May 1, 2003 | 10:01 PM
SpoolnG2's Avatar
Default Re: upgrading my t3/t4, suggestions? (TurboDANDEE)
i dont know why u need to upgrade? that turbo will net u 500whp. that is quite a large a/r and i really don't think u need to upgrade. just crank it to 25psi on some c16 and a good fuel management system, and i'll think you'll see the numbers u want.
Old May 1, 2003 | 10:14 PM
tony1's Avatar
Without knowing what trim it is you don't know if it will make 500hp. You need the details bro, it's all in the details...
Old May 1, 2003 | 10:21 PM
SpoolnG2's Avatar
Default Re: upgrading my t3/t4, suggestions? (tony1)
your right man..i just assumed it would be like a 60 trim with atleast a stage 3 wheel if not a stage 5 since he has such a large a/r. so yeah, what r the details? what trim and what wheel are we talkin here?
Old May 2, 2003 | 12:10 PM
egg's Avatar
egg
its a T31 .60 ar 60 trim, T04E .82 ar stage 3 wheel.
i was thinking something along the lines of a T350/T04S turbo or something similar. thanks for your help guys
Modified by egg at 10:59 PM 5/2/2003
Old May 2, 2003 | 12:20 PM
RyanAutry's Avatar
The SC44 would be an upgrade.
It supports 565hp within it's efficency range.
Old May 2, 2003 | 01:32 PM
*Boostwerks*'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by egg &raquo;</TD></TR><TR><TD CLASS="quote">its a T31 .60 ar 60 trim, T04E .80 ar stage 3 wheel.
i was thinking something along the lines of a T350/T04S turbo or something similar. thanks for your help guys</TD></TR></TABLE>
I would plan on upgrading that oil feed line along with the turbo swap..
SC44 would do you nicely
Old May 2, 2003 | 01:58 PM
egg's Avatar
egg
Default Re: upgrading my t3/t4, suggestions? (Bryson)
maybe in the future but i dont think its nessecary at all. the rubber hose works fine along with the barb fitting. also i have a fire proof cover for it from aeroquip
Old May 2, 2003 | 02:14 PM
egg's Avatar
egg
arturbo, could you post a list of your SC style turbos (sc44, SC61, etc) and give me a recommendation based on my goals and my current turbo. why are precision turbos better? so far ive searched that they use GT series compressors. ive also read that they have superior spool up.
Old May 2, 2003 | 03:39 PM
lazerus's Avatar
.60 trim T04E should make ~450 whp.
Old May 2, 2003 | 04:30 PM
Arturbo's Avatar
Better than steak
25 Year Member
Default Re: upgrading my t3/t4, suggestions? (lazerus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lazerus &raquo;</TD></TR><TR><TD CLASS="quote">.60 trim T04E should make ~450 whp.</TD></TR></TABLE>
Yup, you can make your HP goals with the turbo you have. If you got an SC44 its the same specs that you have right now. Its a T04E .60 trim. No use in buying a turbo that you already have that will make your HP goals. It all depends who is tunning your car.
art
JDMCIVIC919
Apr 5, 2012 12:10 PM
boostdummy
Jan 21, 2006 09:18 PM
hondahatch741
May 30, 2005 12:36 PM
shawn_crx
Jan 7, 2005 02:27 PM
