read this if you've installed your head unit
Old May 1, 2003 | 02:58 PM
RTE117's Avatar
Default read this if you've installed your head unit
I installed my alpine, but it sits 1/2 inch deep in the dash, what did y'all use as a "frame" around the stereo to fit inside the DIN so it will sit out like it's supposed to instead of sinking cause it's too small.
Old May 1, 2003 | 03:43 PM
vteg's Avatar
New User
Default Re: read this if you've installed your head unit (IDriveAHonda)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IDriveAHonda &raquo;</TD></TR><TR><TD CLASS="quote">I installed my alpine, but it sits 1/2 inch deep in the dash, what did y'all use as a "frame" around the stereo to fit inside the DIN so it will sit out like it's supposed to instead of sinking cause it's too small.</TD></TR></TABLE>
I use the alpine provided frame.
Old May 1, 2003 | 04:07 PM
RTE117's Avatar
Default Re: read this if you've installed your head unit (vteg)
I have that, but it still sinks in, which it isn't supposed to do.. I think car audio places use some sort of plastic fitting
Old May 1, 2003 | 04:15 PM
ALF's Avatar
ALF
You can order an install kit from somewhere like Crutchfield. I didn't have the problem you described. Mine fit right in perfectly with no installation kit.
Old May 1, 2003 | 05:17 PM
vteg's Avatar
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IDriveAHonda &raquo;</TD></TR><TR><TD CLASS="quote">I have that, but it still sinks in, which it isn't supposed to do.. I think car audio places use some sort of plastic fitting</TD></TR></TABLE>
What car do you have? Did you use the pop out teeth on the frame to wedge it in there?
Old May 1, 2003 | 06:33 PM
RTE117's Avatar
97 civic.. the head unit sits there nicely with a very very small gap around the plastic trim of the head unit, but something needs to go behind it to push the head unit out farther
Old May 1, 2003 | 06:38 PM
vteg's Avatar
New User
I am not getting what is wrong If the hu is too far in, you can adjust the frame to get it further out. Do you have pictures?
Old May 2, 2003 | 03:04 AM
BlackThorN's Avatar
did you screw it in?
Old May 2, 2003 | 04:00 AM
t0p_sh0tta's Avatar
Default Re: (BlackThorN)
Do EK Civics need mounting kits? If you've installed the metal sleave/basket/frame thing that the HU slides into, it shouldn't go any further back than that. Maybe you have the wrong sleave, or you should use a backstrap.
Old May 2, 2003 | 04:18 AM
1BlackHatch's Avatar
Default Re: (t0p_sh0tta)
I know in my 2000 DX I didn't need a kit. The 97s had a different bezel though, so they might. You don't need a kit if you mount it in the DIN slot behind the cup holder though.
Old May 5, 2003 | 03:22 PM
dlau420's Avatar
Default Re: (1BlackHatch)
I bought an installation kit at Fry's for $15...
Old May 5, 2003 | 08:13 PM
HiRevn's Avatar
Default Re: (dlau420)
Post up some pictures of it if you can. I just installed an Alpine HU in my Integra and it's pretty much flush with the rest of the dash. I think it looks better, but it may be a different story with Civics.
Crackerballer
Audio / Security / Video
Apr 7, 2013 11:29 AM
Bubble Gum Jr.
May 17, 2007 05:24 AM
E.Honda
Aug 30, 2006 06:43 PM
SmokeU
10
Sep 21, 2004 05:28 PM
Surfer_Sandman
Jul 25, 2004 06:55 AM
