Rebuilding d16
Hi, since I didnt really want to have the hassle of switching in my stock engine for the 2 year smog checks. I wanted to know if rebuilding the d16 (crx SI) engine was worth it. Im not really doing it for pulling the fastest on the track but using it as a learning experience. I wanted to start on it, but what parts will I need. Can you guys suggest any places to get the parts? (I know Pick a part and junkyards are obvious) Any website that you guys can recommend me to? Thanks alot!
Jon
Fluffycabbage@tranceaddict.net
Jon
it may be quite costly- keep that in mind.........
Year Make Engine Product Part# Price
1989 Acura D16A1 pistons(.5 over): Part#7741 $36.07
1991 Acura D16A6 piston rings: Part#7664 $22.18
1991 Honda D16A6 connecting rods: Part#13210-pm6-000 $108.87
1991 Honda D16A6 piston pins: Part#113112-peo-000 $12.28
1991 Honda D16A6 crankshaft oil seal: Part#91212-peo-662 $8.10
1991 Honda D16A6 main bearing oil seal: Part#91214-ph1-004 $16.03
1991 Honda D16A6 oil pan gasket: Part#11251-p01-004 $21.93
1991 Honda D16A6 oil pump: Part#15100-p06-a01 $139.12
1996 Honda D16Y8 headgasket: Part# 12251-p2j-004 $28.43
1991 Honda D16A6 rad hose(upper): Part#19501-pm3-000 $10.00
1991 Honda D16A6 rad hose(lower): Part#19502-pm3-000 $16.82
1991 Honda D16A6 Mainshaft Bearing
1991 Honda D16A6 Crank Bearing(?)
the prices & part numbers were pulled from acuraautomotive.org(?) & firsttexashonda.com
that is a good point- it just adds more to the total cost due to machine work
i would also suggest getting a new cam & valve train- but that will add another $6-700 for something decent
i just had a quick question since the d15b2 is essentially the same motor as the d16a6 could you use all the parts listed above in a d15 and gain the same compression numbers and such (that is of course with a mpfi swap).
thanks dont mean to steal your thread bro. single cam power ownz
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mattED6 »</TD></TR><TR><TD CLASS="quote">i just had a quick question since the d15b2 is essentially the same motor as the d16a6 could you use all the parts listed above in a d15 and gain the same compression numbers and such (that is of course with a mpfi swap).
thanks dont mean to steal your thread bro. single cam power ownz</TD></TR></TABLE>
I think so- they are the same block & head castings. But i don't know for sure....
the old d15's had a different bottom end, but you can still use the d16 pistons. you could have the factory rod's shot peened too, that would add strength, the just get a bunch of ARP stuff to hold it all together
what exactly is different about the block? isn't the head the same casting as a d16a6 w/ different valve springs & a diff cam? if it is teh same casting wouldn't the block be too, just w/ diff internals?
VisualAutoMotoring
Dec 6, 2008 11:38 AM
VisualAutoMotoring
Performance
Nov 20, 2008 07:08 AM
DennisWaller
Apr 17, 2008 03:10 PM
