Performance General Performance oriented Parts (Ex: Camshafts, Electronics, Air Intakes, Exhausts, complete engines)
Engine Build Packages! Lowest Prices of the season!
Old Nov 18, 2008 | 07:12 AM
VisualAutoMotoring's Avatar
Default Engine Build Packages! Lowest Prices of the season!
ALL PISTON SET COMES WITH RINGS, WRIST PINS PLEASE PM OR CALL FOR PRICING! (excluding Canada, International)
CP Piston kit with Eagle H-Beam Rods $770.00 SHIPPED Fedex ! (excluding Canada, International)
ADD ACL STANDARD BEARING TO YOUR BUILD!!! $835.00 SHIPPED FOR CP PISTONS, EAGLE RODS, ACL or Clevite COMPLETE SET OF BEARINGS!(Rods/Mains/Thrust Washers)
PRICE MATCHING AVAILABLE!
Applications available: These are shelf piston part#'s . Custom sizing are available.
Honda SC7055 D16A6 2.953" / 75.0mm STD 1.163 9.0
Honda SC7056 D16A6 2.972" / 75.5mm +.020 / +0.5mm 1.163 9.0
Honda SC7125 D16A6 2.953" / 75.0mm STD 1.163 11.0
Honda SC7126 D16A6 2.972" / 75.5mm +.020 / +0.5mm 1.163 11.0
Honda SC7025 D16Z6 2.953" / 75.0mm STD 1.181 9.0
Honda SC7026 D16Z6 2.972" / 75.5mm +.020 / +0.5mm 1.181 9.0
Honda SC7127 D16Z6 2.953" / 75.0mm STD 1.181 10.5
Honda SC7128 D16Z6 2.972" / 75.5mm +.020 / +0.5mm 1.181 10.5
Honda SC7027 D16Y7 2.953" / 75.0mm STD 1.181 9.0
Honda SC7028 D16Y7 2.972" / 75.5mm +.020 / +0.5mm 1.181 9.0
Honda SC7050 D16Y8 2.953" / 75.0mm STD 1.154 9.0
Honda SC7051 D16Y8 2.972" / 75.5mm +.020 / +0.5mm 1.154 9.0
Acura/Honda SC7000 B16A 3.189" / 81.0mm STD 1.181 9.0
Acura/Honda SC7001 B16A 3.209" / 81.5mm +.020 / +0.5mm 1.181 9.0
Acura/Honda SC7100 B16A 3.189" / 81.0mm STD 1.181 10.5
Acura/Honda SC7101 B16A 3.209" / 81.5mm +.020 / +0.5mm 1.181 10.5
Acura SC7005 B18A1/B1 3.189" / 81.0mm STD 1.181 9.0
Acura SC7006 B18A1/B1 3.209" / 81.5mm +.020 / +0.5mm 1.181 9.0
Acura SC7105 B18A1/B1 3.189" / 81.0mm STD 1.181 10.5
Acura SC7106 B18A1/B1 3.209" / 81.5mm +.020 / +0.5mm 1.181 10.5
Acura SC7010 B18C1 3.189" / 81.0mm STD 1.181 9.0
Acura SC7011 B18C1 3.209" / 81.5mm +.020 / +0.5mm 1.181 9.0
Acura SC7012 B18C1 3.268" / 83.0mm +.080 / +2.0mm 1.181 9.0
Acura SC7015 B18C1 3.189" / 81.0mm STD 1.181 9.8
Acura SC7016 B18C1 3.209" / 81.5mm +.020 / +0.5mm 1.181 9.8
Acura SC7110 B18C1 3.189" / 81.0mm STD 1.181 11.0
Acura SC7111 B18C1 3.209" / 81.5mm +.020 / +0.5mm 1.181 11.0
Acura SC7112 B18C1 3.268" / 83.0mm +.080 / +2.0mm 1.181 11.0
Acura SC7115 B18C1 3.189" / 81.0mm STD 1.181 12.5
Acura SC7116 B18C1 3.209" / 81.5mm +.020 / +0.5mm 1.181 12.5
Acura SC7135 B18C5 3.189" / 81.0mm STD 1.195 11.5
Acura SC7136 B18C5 3.209" / 81.5mm +.020 / +0.5mm 1.195 11.5
(X-Style Forging Piston sets. B16 head application will net around 13.6:1 compression and B18C head will net 14.1:1 compression)
Acura SC7123X B - Series 3.346" / 85.0mm +.040 / +1.0mm 1.181 +7.7cc
Acura SC7124X B - Series 3.386" / 86.0mm +.080 / +2.0mm 1.181 +7.7cc
Honda SC7020 B - Series 3.307" / 84.0mm STD 1.181 9.0
Honda SC7021 B - Series 3.327" / 84.5mm +.020 / +0.5mm 1.181 9.0
Honda SC7022 B - Series 3.346" / 85.0mm +.040 / +1.0mm 1.181 9.0
Honda SC7017 B - Series 3.307" / 84.0mm STD 1.181 9.7
Honda SC7018 B - Series 3.327" / 84.5mm +.020 / +0.5mm 1.181 9.7
Honda SC7019 B - Series 3.346" / 85.0mm +.040 / +1.0mm 1.181 9.7
Honda SC7120 B - Series 3.307" / 84.0mm STD 1.181 12.5
Honda SC7121 B - Series 3.327" / 84.5mm +.020 / +0.5mm 1.181 12.5
Honda SC7122 B - Series 3.346" / 85.0mm +.040 / +1.0mm 1.181 12.5
Acura/Honda SC7040 K20A/A2/A3 3.386" / 86.0mm STD 1.181 9.0
Acura/Honda SC7140 K20A/A2/A3 3.386" / 86.0mm STD 1.181 11.5
Acura/Honda SC7142X K20A/A2/A3 3.386" / 86.0mm STD 1.181 12.5
Acura/Honda SC7045 K24 w/K20A/A2/A3 3.425" / 87.0mm STD 1.181 9.0
Acura/Honda SC7145 K24 w/K20A/A2/A3 3.425" / 87.0mm STD 1.181 11.5
Acura/Honda SC7147X K24 w/K20A/A2/A3 3.425" / 87.0mm STD 1.181 12.5
Honda SC7030 H22A1 3.425" / 87.0mm STD 1.220 9.0
Honda SC7130 H22A1 3.425" / 87.0mm STD 1.220 10.0
Honda SC7131 H22A1 3.425" / 87.0mm STD 1.220 11.5
Old Nov 20, 2008 | 07:08 AM
PM's replied Thanks!
VisualAutoMotoring
Dec 6, 2008 11:38 AM
VisualAutoMotoring
Dec 1, 2008 10:10 AM
Visionaryauto
Performance
218
Nov 24, 2008 06:32 PM
VisualAutoMotoring
Nov 7, 2006 05:13 AM
ExtremePowerOuters
Aug 28, 2006 05:38 PM
