Another suspension question...
Old May 1, 2003 | 12:16 PM
aengnr1's Avatar
Default Another suspension question...
welp, as you can tell, im new, so we'll start with hi! Anyway, I've got a 94DX 5spd with about 120k on it that i just got a few weeks ago and im going to go nuts on it in the next week with oil, fuel/air/oil filter, valve adjustment, dist cap/rotor, plugs/wires, flush/fill radiator and tranny....just to make sure its all up to par. Anyway, I figured its time to do something about the susp too. Its stock as far as I can tell and it drives like a wet noodle (alot of roll and not inspiring at high speed). I want to stiffen it up without lowering it too much (i dont care about the look) bc its a daily driver and i dont want a really harsh ride. After searching the board, it seems the AGX's are the way to go, but i was considering the pro-kit or the neuspeed sofsports for a minimal drop but still increase performance. What do you guys think about either one of these setups? and would it be overwhealmingly better handling if i just went with a more aggressive drop, a la neuspeed sports? Also, any other reasonable recommendations (ie, im a college $tudent) to stiffen things up would be helpful....Thanks in advance....
Old May 1, 2003 | 12:28 PM
carolinaACCORD's Avatar
Default Re: Another suspension question... (aengnr1)
hi, welcome.
the AGX's and Pro kit would be a good combo and not too expensive.
also, you can get a cheap strut tower bar off of ebay, a front would be good enough, i think.
Old May 1, 2003 | 11:08 PM
.bagged's Avatar
Default Re: Another suspension question... (carolinaACCORD)
Try GC with tokico blues you wont be disappointed you spent the money.. if that doesnt work you could always put it on AIR. good luck to your and WELCOME
Old May 1, 2003 | 11:11 PM
iam7head's Avatar
Default Re: Another suspension question... (bagged93accord)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bagged93accord &raquo;</TD></TR><TR><TD CLASS="quote">Try GC with tokico blues you wont be disappointed you spent the money.. if that doesnt work you could always put it on AIR. good luck to your and WELCOME </TD></TR></TABLE>
put it on air=air bags? that's good for show, not cornering as far as i know.
tokico blues is fine for it price but you'll be happy with agx or koni
Ground Control=
just go around and ask, most of the shop will not recommend it.
it's not a real coilover.
went you try to do something, do it right the first time save you alot of money.
eibach and h&r make some good springs.
eibach w/ agx will be serve you well for that kind of money spent.
Old May 2, 2003 | 05:14 AM
RABBIT9's Avatar
Default Re: Another suspension question... (iam7head)
I running Tockico Illuminas with an Eibach Pro-Kit. The ride is great, especially considering the increase in handling you get.
Cloud7659
Suspension & Brakes
19
Aug 29, 2011 02:34 AM
Rikaro
Nov 23, 2008 06:20 PM
Pele
Feb 12, 2004 11:46 AM
LoooseGSR
Jul 14, 2003 10:27 AM
integtypr01
Jun 29, 2003 11:33 PM
