B18C1--Cleaning the head.....
Old May 1, 2003 | 10:59 AM
MikeTV
Guest
Posts: n/a
Default B18C1--Cleaning the head.....
This weekend, I plan on taking my valve cover off, to check my valves/pistons/change spark plugs etc.) I was just wondering a few things:
1. When I take the head off, is it essential to buy a new head gasket, or can I reuse the old one ? And do I have to seal the valve cover with HONDA BOND or anything when I put it back on ?
2. Is there any type of spray that I could use on the valves in order to clear any grime off of them ?
3. what are the best spark plugs/wires to get for the b18c1 ?
Old May 1, 2003 | 11:04 AM
IN VTEC's Avatar
Default Re: B18C1--Cleaning the head..... (Eclipse spanker)
Replace head gasket. Not worth the extra 4 hours you have spend to replace it after you find it leaks.
You don't have to replace the valve cover gasket unless it's torn or disfigured beyond usefulness (unless you just like or want to for the sheer pleasure of it). Use a thin smear of Hondabond on the corners of the gasket next to the semi-circles.
I'm not sure about cc cleaning. ATF? Seafoam stuff?
Use NGK PFR6G-13 plugs and stock wires.
Old May 1, 2003 | 11:30 AM
romeo619romeo's Avatar
answers
#1 yes buy a new headgasket.. and no you cant reuse.. no dont need honda bond...make sure the valve cover gasket is still rubbery.. not stiff... is so buy a new one...also wipe all the oil off the surrounding area if there is oil...
#2your better off using the injector cleaner.. the type taht hooks up to the intake manifold.. one of the vacuum lines...ask your local autp part store they will ko what im talking about....
#3 denso/ngk .. same makers ..plugs stock
Old May 1, 2003 | 01:24 PM
acatak's Avatar
Default Re: B18C1--Cleaning the head..... (romeo619romeo)
How much do the NGK PFR6G-13's cost?? IS there anything cheaper?
Old May 1, 2003 | 01:45 PM
OBDI JEDI's Avatar
Default Re: B18C1--Cleaning the head..... (acatak)
use the copper NGK plugs only $1.99 a piece
Old May 1, 2003 | 01:48 PM
IN VTEC's Avatar
$12.35/plug at clubplug.net
I like the electrode design of the laser platinums better than the regular copper plugs.
Old May 1, 2003 | 02:02 PM
OBDI JEDI's Avatar
Default Re: B18C1--Cleaning the head..... (IN VTEC)
copper conducts better then platinum
platinum just doesnt have to be changed as often
Old May 1, 2003 | 03:26 PM
IN VTEC's Avatar
Default Re: B18C1--Cleaning the head..... (OBDI JEDI)
That's true, but once voltage is built up at the tip of the electrode, electrode composition ceases to matter. It has to conduct across non-ferrous air/gas, not copper (or platinum) when it jumps the gap.
If somebody had the equipment, you could test and compare the minimum amount of voltage required for it to arc b/w the two electrode designs. There's also a time variable to be concerned about as to how quickly the plug reaches full voltage - where copper may have an advantage.
Old May 1, 2003 | 03:29 PM
OBDI JEDI's Avatar
good point, but i just hate paying in excess of 5 dollars per plug, when i can use copper and just swap them out every 5000 miles.
Old May 1, 2003 | 03:46 PM
IN VTEC's Avatar
I had issues with the BKR3E's gapped to something like 1.289". Took more cranks to start the engine and gas mileage suffered. Just my personal experience, so I never use them anymore.
jdm mini me
10
Mar 25, 2010 09:04 PM
egg_baLLa
Jun 21, 2008 04:29 PM
DCf4i
11
Jan 7, 2008 01:44 PM
JDM_d15b_eg8
23
Aug 27, 2006 02:27 PM
Dorksk8tr3
Aug 18, 2005 09:46 AM
