ZC vs D16Y8 Head flow charts (Thanks to Earl)...
Old May 1, 2003 | 09:40 AM
*Boostwerks*'s Avatar
Default ZC vs D16Y8 Head flow charts (Thanks to Earl)...
I just thought I would start another thread with both graphs to compare. I know some people have been interested in seeing this...
To bad we don't have a Z6 graph to show as well.
Both Heads have been ported by Earl's shop.
(The graphs do have different #'ed axis' so be careful)
D16Y8:
ZC:
The D16Y8 definetly improved more than the ZC head in intake flow, but the ZC improved more in Exahust flow.
(Courtesy of Earl)
Bryson
Old May 1, 2003 | 10:51 AM
@irborne's Avatar
Default Re: ZC vs D16Y8 Head flow charts (Thanks to Earl)... (Bryson)
from looking at both graph...the y8 probably is better for boost??!!?!!?
Old May 1, 2003 | 11:05 AM
Default Re: ZC vs D16Y8 Head flow charts (@irborne)
I doubt it. From what I can tell, the ZC is better from the overall higher exhaust flow.
Old May 1, 2003 | 11:09 AM
92HB_HB's Avatar
here is a newb question.. are the zc and y8 heads interchangable on a ex block?? my neighbor has a zc motor sittin in her garage and i think this might be a nice project..
Old May 1, 2003 | 11:11 AM
sparq's Avatar
Default Re: ZC vs D16Y8 Head flow charts (Bryson)
ZC r0x0rs!
Im going to let Earl play with my head soon... wait that sounds bad
Old May 1, 2003 | 11:17 AM
boosted hybrid's Avatar
Default Re: ZC vs D16Y8 Head flow charts (sparq)
Very interesting charts. The y8 does flow much better on the intake, but the exhaust of both the zc and y8 are pretty close. From what i have seen being around, and porting the z6/y8 heads the exhaust ports are identical. I would like to see what the zc exhaust ports are shaped like to create a much better flow. I am fairly certain that you could model the exhaust porting off of the zc head on the exhaust port to get the y8 even closer to the flow of the zc. Remember that there is more to the equation than just the head porting for overall flow.
Old May 1, 2003 | 01:38 PM
Default Re: ZC vs D16Y8 Head flow charts (92HB_HB)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92HB_HB &raquo;</TD></TR><TR><TD CLASS="quote">here is a newb question.. are the zc and y8 heads interchangable on a ex block?? my neighbor has a zc motor sittin in her garage and i think this might be a nice project..</TD></TR></TABLE>
No. Head Bolt pattern is different.
Old May 1, 2003 | 02:01 PM
@irborne's Avatar
Default Re: ZC vs D16Y8 Head flow charts (boosted hybrid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boosted hybrid &raquo;</TD></TR><TR><TD CLASS="quote">I would like to see what the zc exhaust ports are shaped like to create a much better flow. I am fairly certain that you could model the exhaust porting off of the zc head on the exhaust port to get the y8 even closer to the flow of the zc.</TD></TR></TABLE>
i believe if porting the y8's exhaust side into similar characteristic as the zc's, the y8 would yield equal or more power.
Old May 1, 2003 | 02:22 PM
SiRkid's Avatar
I got a ride in a turbo (14b)zc powered crx....it was very quick!
alanvtec
Feb 20, 2014 03:00 AM
D16y8_Rebuild
Feb 28, 2006 09:03 PM
itsmetyler
Dec 22, 2005 11:05 PM
CivicRaping
Jul 25, 2005 04:12 PM
vietnameeh
Apr 3, 2005 04:07 AM
