help!! my shift linkage is pissing me off!@#$ 56k noo!
Old May 1, 2003 | 08:59 AM
lsvtec101's Avatar
Default help!! my shift linkage is pissing me off!@#$ 56k noo!
after my bottom end swap, i cant get my dam shift linkage to line up rigght,,, theres only two ways the shift linkage can go on... i know i have it on the correct way it has to be this way... but i can shift into all of the gears, my shifter is all the way to the passengers side... any ideas on what the hell is going on???????
Old May 1, 2003 | 09:22 AM
sivik2nr's Avatar
Default Re: help!! my shift linkage is pissing me off!@#$ 56k noo! (aemcivic_02917)
Do you mean the shifter is really sloppy? You can shift to every gear but the shifter handle goes way over to the side?
What are you using to connect the linkage to the tranny? If you just use a regular bolt through it, then it's gonna be like that. You have to order from Honda a shift linkage pin and clip. I think they are under $5 for both together.
Or are you saying that the shift pattern is just off set? Like the shifting is tight, but it's over to the passenger side more?
Modified by sivik2nr at 12:57 PM 5/1/2003
Old May 1, 2003 | 09:34 AM
lsvtec101's Avatar
Default Re: help!! my shift linkage is pissing me off!@#$ 56k noo! (sivik2nr)
the shift pattern is off set , i can shift into gears but not all of them, its moved over more to the passengers side.
i did use a new pin from honda too
Modified by aemcivic_02917 at 11:00 AM 5/1/2003
Old May 2, 2003 | 04:07 AM
lsvtec101's Avatar
ttt
Old May 2, 2003 | 08:17 AM
DEVIN22CBR's Avatar
Default Re: (aemcivic_02917)
I went out and looked at mine man ...I think yours is upsdie down ..Might wanna try one more time
BiGcAmBoDiAnSaUsAgE
Mar 23, 2007 10:56 PM
UrVtecIsLoud
Jul 26, 2006 07:26 PM
bOOsted_D16
May 17, 2006 04:28 AM
91SiRX
Jun 10, 2005 07:41 PM
