obd0 pr3 compatible with obd0 d16y8?
Old May 1, 2003 | 06:40 AM
50shotRex's Avatar
Default obd0 pr3 compatible with obd0 d16y8?
im gonna be running a d16y8 in my car, and i have access to a b16a pr3, just wondering if i convert the d16y8 to obd0 will i be able to run the pr3 with it, with the non vtec si distributor>? any help is appreciated, this ecu will be used only for track use
Old May 1, 2003 | 07:08 AM
zCivic's Avatar
Default Re: obd0 pr3 compatible with obd0 d16y8? (50shotRex)
you can run it, you will need to run the wires for the oil pressure sensor, vtec silonoid, 2nd o2 sensor and run a knock sensor or ground it. You can also run a Mugen N1 program that will disable everything except the V-tec silonoid but usually they have no rev limit. If you go thru all the work using the stock rom I would keep it in instead of having to swap pins back and forth....
Old May 1, 2003 | 08:10 AM
50shotRex's Avatar
Default Re: obd0 pr3 compatible with obd0 d16y8? (zCivic)
thx dude
denraweb
May 11, 2009 06:25 PM
emerica42
Mar 12, 2009 11:50 AM
ef9wannabe
Dec 4, 2008 04:13 PM
alscrx
Sep 14, 2008 06:47 PM
