wheels arent balanced correctly, or warped rotors??
only happens when i brake when im going around 65 and up.. wont happen if i brake easily.. but if i apply alot of pressure to the pedal, steering wheel will shake.. also when i hit a speed between 60-65, i'll get a slight "shudder" in the wheel.. but it will go away when i get out of that "mph zone".. unbalanced wheels?? rotors warped?? thanx..
Nope its an alignment problem. I had the exact same thing happen to me when I first got my prelude. Trust me its alignment, probably bad toe.
alright thanx guys.. im gonna go get the alignment checked out soon..
but another question.. if the alignment was off, would i have unusual wear on my tires?? i just looked at them and it seems that their wearing fine.. hmm..
Are you running on aftermarket wheels? And if so, are you using hubcentric rings to correct the centerbore size? ALWAYS use hubcentric rings if your wheel bore does not match your hub bore!
Andrew
Andrew
speedehatch
Dec 3, 2003 11:57 AM
m0dr0cker
14
Oct 27, 2003 01:35 PM
