What harness should I use???????
Old Apr 30, 2003 | 08:45 PM
EGJDM's Avatar
Default What harness should I use???????
I am swapping a ITR motor into my 1994 integra what would be my best option of harness? Sould I just use a OBD1 harness and then all I would have to change would be the plug for the distributor right?
Old Apr 30, 2003 | 09:46 PM
ghettocrxsi's Avatar
Default Re: What harness should I use??????? (EGJDM)
Just use your wiring harness. then just use your ls distributor.
Old May 1, 2003 | 04:33 AM
VTECVillain's Avatar
Default Re: What harness should I use??????? (ghettocrxsi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ghettocrxsi &raquo;</TD></TR><TR><TD CLASS="quote">Just use your wiring harness. then just use your ls distributor. </TD></TR></TABLE>
The LS distributor will not bolt up to the ITR head. You can use an OBDII GSR/ITR harness and keep all the components OBDII on the motor, or change the injector plugs (reuse the OBDI injectors as well) and distributor plugs to OBDI and use your stock harness.
Evan214
Jul 6, 2020 09:32 AM
JoeBlue
Jan 9, 2014 08:01 AM
4dek
Jul 6, 2008 06:13 PM
Hoppa
May 12, 2006 01:16 PM
baonest
Aug 8, 2002 09:11 PM
