one quick question, can someone verify this for me?
Old Apr 30, 2003 | 05:51 PM
GSblueRacing's Avatar
Default one quick question, can someone verify this for me?
If I want to take the OEM steering wheel(wth airbag) out, and place it back again later, 1)Do I have to first take out the Case(upper and lower) covering the steering column and 2) disconnected the battery?
Old Apr 30, 2003 | 07:57 PM
Brasspremier's Avatar
Default Re: one quick question, can someone verify this for me? (GSblueRacing)
not sure but i'd check out manual to make sure you do everything right
Old May 1, 2003 | 10:36 AM
Default Re: one quick question, can someone verify this for me? (Brasspremier)
anyone?
Old May 1, 2003 | 10:40 AM
dohc-nyne's Avatar
if u dont have an air bag then u shouldnt have to d/c the battery but i would for safe measure....anyways,,,take off the two side bolts that hold the airbag in place...use a torx screwdriver 30....remove the air bag if u have one...if not the d/c ur power steering harness and horn harness and airbag harness...then take off the steering wheel locking nut in the middle...then wiggle the steering wheel off....to put back on...just do steps backwards....
dohc-nyne's Avatar
yah...100 posts,,,,and a helpfull one too....
teggy_617
Jan 6, 2010 03:21 AM
BoboyRS
Feb 3, 2009 11:19 PM
buffdaddy357
Oct 25, 2008 06:41 PM
93egboosted
Sep 5, 2007 01:17 PM
boostin b16
Mar 21, 2003 01:24 PM
