Can anyone tell me if I did this wiring right?
Old Apr 30, 2003 | 05:10 PM
FourthGenHatch's Avatar
Default Can anyone tell me if I did this wiring right?
On the back of the block there is some sensor with male "prongs" on it, in a stacked formation. One wire is black one is yellow. I stuck the yellow wire at the top and the black at the bottom. I can't remember how they were when I first took them off so I wanted to know if this was right or not.
Old Apr 30, 2003 | 05:57 PM
civickiller's Avatar
Default Re: Can anyone tell me if I did this wiring right? (FourthGenHatch)
u know fourthgenhatch, im in the same predicament as u are right now, i took those wires off and i dont remember which one goes where
Old Apr 30, 2003 | 06:09 PM
Default Re: Can anyone tell me if I did this wiring right? (civickiller)
Yeah I meant to look today at a car in the junkyard to see what the placement was but I forgot.
Old Apr 30, 2003 | 07:37 PM
SIRX's Avatar
between the back of alt. and the oil filter. I believe this is the oil pressure sending unit. Anyway the black on is on top. I just checked
Old Apr 30, 2003 | 07:46 PM
Default Re: Can anyone tell me if I did this wiring right? (SIRX)
Ok I better switch that real quick before I have no oil or some crap!
Old Apr 30, 2003 | 08:30 PM
OldSchoolHatch's Avatar
I had the same question a little while ago, but they were side by side on mine. I was told it doesn't matter which goes where - that sensor is for your radiator fan. They could be wrong though, here's the thread:
https://honda-tech.com/zerothread?id=463369
Old Apr 30, 2003 | 08:42 PM
Slurp56's Avatar
Default Re: Can anyone tell me if I did this wiring right? (OldSchoolHatch)
oldschoolhatch is completely corect. Its your rad fan switch. does not matter if the wires are reversed. When the switch heats up, it provides continuity between the two prongs. The completes the circuit and provides the ground for your rad fan.
Old May 5, 2003 | 01:40 AM
truent's Avatar
Default Re: Can anyone tell me if I did this wiring right? (Slurp56)
damn too late, read that first post and couldnt wait to be captain-save-a-swapper.. heh yeah interchangeable.. good job
j_the_guy
Mar 10, 2019 11:33 PM
kixcrx
Mar 28, 2007 03:20 PM
projsectEF
16
May 22, 2006 04:19 PM
dan89crxsi
Nov 26, 2003 10:26 AM
OldSchoolHatch
Apr 3, 2003 05:03 AM
