Engine bay cleaning???
Guest
Posts: n/a
Gotta clean that dirty engine bay of mine......damn splash shields ripped off and the nasty winter rains got up in the bay and have made a mess.......I know i need to cover the distributor.....what other systems would you guys recommend to cover??? Should i blast off the loose dirt or use low pressure water? Is soap dangerous to anything in the engine?
I use a degreaser called purple power. Spray it on when the motor is hot at a jet spray car wash. Let it sit for a minute and then spray it off. Take it home make sure everything is dry and sprayed black magic on everything. Then I proceed to wipe everything down. It turns out real nice. DO NOT do this if you have a ceramic coated header though. If you have one do it when its cold. If you do it when its hot it WILL discolor the header.
Yes, do leave it running. Otherwise be careful and cover up the distributor, alternator, etc. I've washed mine while it was running many times without a problem, but 2 weeks ago when I washed it while not running, I accidently got water in the alternator and fried it. Actually I'm not sure if it fried it completely cuz when I took it out there was some standing water inside of it that may have caused it to short but not kill it completely, but it got really really hot and drained the battery. Luckily I found a fresh reman at the junkyard for $13.50
Oh yes, Simple Green, a scrub brush, and a toothbrush work wonders!
Might be a dumb question but what do you cover up the distributer and stuff with? I usually just get under there with a rag and then with something to get everything nice and wet looking. It usually looks good but there are a couple of place I can't reach that a pressure hose would at the local wash.
I have detailed for about three years. Ive cleaned up probably thousands of motors. Never once have I covered anything up. You just have to be careful. Dont apply direct pressure to the distributor, around your filter box(if you dont have a intake), and brake fluid resivor(SP??) Its not very hard, just take your time. In the end youll be happy you did. Any other quetions feel free to ask me. My aim is H22Accd91 or just email me. Hope this helps.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kasper »</TD></TR><TR><TD CLASS="quote">Might be a dumb question but what do you cover up the distributer and stuff with? I usually just get under there with a rag and then with something to get everything nice and wet looking. It usually looks good but there are a couple of place I can't reach that a pressure hose would at the local wash.</TD></TR></TABLE>
I use a plastic bag...
mynameizstitch
Jul 3, 2009 04:15 PM
