How do I find an exhaust leak???
Old Apr 30, 2003 | 04:16 PM
tc's Avatar
tc
Default How do I find an exhaust leak???
Hi everyone,
I hear what sounds like a fluttering sound when I let off the gas. It sounds like an exhaust leak. Is there anyway to pinpoint the location without taking it to a shop? Thanks!
Old Apr 30, 2003 | 04:21 PM
obd2gsr's Avatar
Default Re: How do I find an exhaust leak??? (tc)
get close to the ground and listen. have your friend rev it up a little bit, and listen for the exhaust leak. try it next to a wall, so you can hear it better.
i had a small exhaust leak, but it was because the gasket between the muffler section and b-pipe was bad.
Old Apr 30, 2003 | 04:23 PM
Hooch'n's Avatar
Default Re: How do I find an exhaust leak??? (obd2gsr)
Sometimes their will be water drips.......If it is small i wouldn't worry about it, you could tell if it was real bad.
Old Apr 30, 2003 | 04:42 PM
tc's Avatar
tc
Default Re: How do I find an exhaust leak??? (Hooch at 8400-RPM)
If I can hear it, doesn't that make it bad? I figure if it wasn't too bad than I wouldn't be able to hear it. I was told if there's a leak it affects performance. Any way to tell besides by listening? I tried to listen, but all I hear is the loud muffler....
Old Apr 30, 2003 | 05:34 PM
Teepo's Avatar
Jack it up or put on lift. turn it on and cover the exhaust your hand(cover hand with a rag)......create backpressure......dont keep your hand on it., 3-5 secs.
watch that b*tch leak
Old Apr 30, 2003 | 05:42 PM
1GreyTeg's Avatar
Default Re: How do I find an exhaust leak??? (ITR1150)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ITR1150 &raquo;</TD></TR><TR><TD CLASS="quote">Jack it up or put on lift. turn it on and cover the exhaust your hand(cover hand with a rag)......create backpressure......dont keep your hand on it., 3-5 secs.
watch that b*tch leak </TD></TR></TABLE>
This is what you should do.
Of course do it with the doors open or even outside.
Old Apr 30, 2003 | 06:02 PM
morepoop4u's Avatar
Default Re: How do I find an exhaust leak??? (1GreyTeg)
eventually the carbon deposits will build up where it is leaking
Old Apr 30, 2003 | 07:11 PM
dextR's Avatar
Default Re: How do I find an exhaust leak??? (morepoop4u)
also look for black carbon spray on the underside of the car where the exhaust runs down (top of exhaust that is not visual to the eye) the carbon soot will mix with the condensation and sometimes spray out of the leak
Old May 1, 2003 | 08:13 AM
tc's Avatar
tc
Default Re: How do I find an exhaust leak??? (dextR)
Thanks for the advice!
Will covering up the muffler cause any harm to the engine?
Old May 1, 2003 | 10:00 AM
emr88's Avatar
Easy way, if you suspect it's a weld is to spray paint the weld area with silver or white paint. You'll see a black dot or dots where the leak is at.
guymontag
Jul 28, 2007 03:10 PM
Mikes2000civicsi
23
Dec 24, 2006 12:27 PM
Luchini
Aug 11, 2006 05:25 AM
VeeTech Lude
Sep 20, 2005 10:35 AM
Batoutahell
Aug 5, 2003 06:33 PM
