somethings wrong with my VTEC!!!! someone please help
Old Apr 30, 2003 | 02:08 PM
ATF Kuk's Avatar
Default somethings wrong with my VTEC!!!! someone please help
my VTEC isnt working correctly, i dont know wuts wrong. well, as i was catching the freeway on ramp, i gunned it and VTEC'd it in 2nd. the on ramp curves and as i was on the curve, the motor just stopped making power like i hit redline. but thats impossible cuz i was only at like 7,500 rpm and i have a chipped P28 to redline at 10,000 with VTEC engagement at 5,700. so when it stopped making power, i shifted up to 3rd and the motor worked normally. but since i was scared that somethign went wrong, i exited the freeway and VTEC'd at every light. now the VTEC hits at 6,200 rpm everytime and sometimes the damn VTEC doesnt even engage until like 7,500-8,000 rpm. when i take turns or curves, VTEC doesnt even kick in at all.
i checked the VTEC soleniod connection and its seems ok. does anyone have any idea of wut the problem is? any info is much appreciated
Old Apr 30, 2003 | 02:09 PM
vtecvoodoo's Avatar
Future Texas Boy
Community Builder
Default Re: somethings wrong with my VTEC!!!! someone please help (ATF Kuk)
check oil level.
Old Apr 30, 2003 | 02:13 PM
RedR's Avatar
if u notice that when u do curves u r low on oil
Old Apr 30, 2003 | 02:18 PM
ATF Kuk's Avatar
Default Re: somethings wrong with my VTEC!!!! someone please help (RedR)
thanx guys, ill go check that right now
Old Apr 30, 2003 | 02:21 PM
ATF Kuk's Avatar
it doesnt seem to be low, its above the low dot mark, but ill add some later tonight and ill see if its better, until then, thanx again guys
Old Apr 30, 2003 | 02:23 PM
B2FiNiTY's Avatar
Are you checking it cold and on level ground?
Old Apr 30, 2003 | 03:03 PM
ATF Kuk's Avatar
Default Re: somethings wrong with my VTEC!!!! someone please help (B2FiNiTY)
its warm and im not sure if its level. seems pretty level
Old Apr 30, 2003 | 03:10 PM
B2FiNiTY's Avatar
Check again when cold.
Old Apr 30, 2003 | 03:14 PM
baonest1's Avatar
check your flux capacitor...
hope everything gets fixed... most likely your oil
Old Apr 30, 2003 | 03:17 PM
AssPenny's Avatar
Default Re: somethings wrong with my VTEC!!!! someone please help (baonest)
Was your seat reclined to a 45 degree angle? Did you do a 'MaD ShIfT' into V-tEcH mode?
Old Apr 30, 2003 | 03:51 PM
jdmspoonitr's Avatar
Default Re: somethings wrong with my VTEC!!!! someone please help (AssPenny)
Oil level should be at the highest dot. Being in between dots means you are low, not "okay". Check when cold.
Old Apr 30, 2003 | 03:54 PM
Type-Rare#1248's Avatar
Default Re: somethings wrong with my VTEC!!!! someone please help (jdmspoonitr)
must be oil lever
Old Apr 30, 2003 | 03:55 PM
BDiddy's Avatar
Default Re: somethings wrong with my VTEC!!!! someone please help (Type-Rare#1248)
check your spelling too. Thats definitly not at the correct level.
Old Apr 30, 2003 | 04:28 PM
RickV's Avatar
Default Re: somethings wrong with my VTEC!!!! someone please help (BDiddy)
Same thing happened to me when the oil was on the bottom dot. As soon as I topped it up it was all ok. I'm pretty sure it is an engine protection thing so that you can't puch the engine hard if the oil is low.
Old Apr 30, 2003 | 04:33 PM
dimsum's Avatar
Default Re: somethings wrong with my VTEC!!!! someone please help (RickV)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RickV &raquo;</TD></TR><TR><TD CLASS="quote">Same thing happened to me when the oil was on the bottom dot. As soon as I topped it up it was all ok. I'm pretty sure it is an engine protection thing so that you can't puch the engine hard if the oil is low.</TD></TR></TABLE>
Yup...when the oil pressure goes low, VTEC no workie.
Old Apr 30, 2003 | 04:35 PM
Floyd's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RickV &raquo;</TD></TR><TR><TD CLASS="quote">I'm pretty sure it is an engine protection thing so that you can't puch the engine hard if the oil is low.</TD></TR></TABLE>
No, it has to do with low oil pressure not engaging the vtec solenoid.
Old Apr 30, 2003 | 04:50 PM
D's Avatar
D
engine protection thing? where do people come up with this ****?
Old Apr 30, 2003 | 04:53 PM
ArmyGreenITR's Avatar
Default Re: somethings wrong with my VTEC!!!! someone please help (D)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D &raquo;</TD></TR><TR><TD CLASS="quote">
engine protection thing? where do people come up with this ****?</TD></TR></TABLE>
hahah owned
Old Apr 30, 2003 | 05:11 PM
RickV's Avatar
Default Re: somethings wrong with my VTEC!!!! someone please help (ArmyGreen EG)
Like everyone else who has no idea - make it up!
But think about it - would you want your engine being pushed hard by VTEC if there is not enough oil in it?
Old Apr 30, 2003 | 05:26 PM
.RJ's Avatar
.RJ
Your VTEC is obviously wearing out.
You need to install the smaller B15 (rare JDM motor) oil filter so that your VTEC kicks harder. Dyno tested for a 8hp and 6ft-lbs gain all through VTEC.
Old Apr 30, 2003 | 05:33 PM
Floyd's Avatar
Default Re: somethings wrong with my VTEC!!!! someone please help (.RJ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .RJ &raquo;</TD></TR><TR><TD CLASS="quote">Your VTEC is obviously wearing out.</TD></TR></TABLE>
Yeah, I had to replace my vtec at 65,000 miles. I was able to get it covered under warranty though.
Old Apr 30, 2003 | 06:20 PM
95GS-Racin's Avatar
You need to install the smaller B15 (rare JDM motor) oil filter so that your VTEC kicks harder. Dyno tested for a 8hp and 6ft-lbs gain all through VTEC.</TD></TR></TABLE>
This is a very good point. I added one on my B20Vtec and she gained 12 horsepower after tuning
Old Apr 30, 2003 | 07:05 PM
dextR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by baonest &raquo;</TD></TR><TR><TD CLASS="quote">check your flux capacitor... </TD></TR></TABLE>
yup, that'll do it to ya every time
Old Apr 30, 2003 | 10:48 PM
Nameless RB26's Avatar
Default Re: somethings wrong with my VTEC!!!! someone please help (dextR)
vtec not working = end of the world.
Old May 1, 2003 | 02:44 AM
MiraiZ's Avatar
Default Re: somethings wrong with my VTEC!!!! someone please help (Nameless EJ6)
I recharge my vtec every night...will never experience lack of vtec on my car
