code 16
Can't help with the swap, but code 16 is set when the ECU sees a break in the electrical circuit coming from the injectors. The electrical path is roughly ...
the ignition switch and fuse, main relay, resistors, injector coils, and then the ECU grounds the circuits as required. Check your wiring and the main relay for starters.
Code 16 - Fuel Injector
Code 16 is probably the Main Relay, however it could still mean a bad Injector, Resistor Box tho.
Most failures occur, when the weather starts heating-up for the summer...
If the car refuses to start, but "turns over" on a hot day, try opening the doors/windows, and let the interior cool down. "Then try starting again". May not work all the time, but worth a try anyway. Also, would help in troubleshooting the prob, if it does start. Another place to look is the ECT sensor, refer to the above
EF2_BoogieMan
Jan 5, 2015 06:47 AM
allm0torGSR
Apr 30, 2004 05:10 PM
pokemon
Jul 26, 2003 09:24 AM
