wtf is wrong w/mycar
Old Apr 30, 2003 | 09:30 AM
97H22's Avatar
Default wtf is wrong w/mycar
my car wont start. when i have the head light on (very dim) and the car wont crank or start, when the light is off the car crank but still no start. has this happen to any one before
Old Apr 30, 2003 | 09:31 AM
trahsub's Avatar
Default Re: wtf is wrong w/mycar (97H22)
Sounds like a dead battery.
Old Apr 30, 2003 | 09:46 AM
preylude99's Avatar
Default Re: wtf is wrong w/mycar (trahsub)
most likely the battery
Old Apr 30, 2003 | 09:59 AM
97H22's Avatar
Default Re: wtf is wrong w/mycar (preylude99)
i thought it was the battery too but is not , i test my battery at autozone and they said it was still good but i went ahead and drop it off over night. the next day i pick it up and put back in my car and still do the same thing. this all happen when i broke my timing belt.
Old Apr 30, 2003 | 11:42 AM
optikal_blitz's Avatar
alternator?
Old Apr 30, 2003 | 11:53 AM
hndacvcjosh's Avatar
it may be the coil in your distributor. My car wouldn't start, and I had to change the coil out so it would start again, if you cannot get spark that probably is what it is.
Old Apr 30, 2003 | 11:59 AM
2002 GT's Avatar
Default Re: (NatakuBlitz)
that would be my guess, alternator....
Old Apr 30, 2003 | 12:13 PM
tha Big EZ's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97H22 &raquo;</TD></TR><TR><TD CLASS="quote">this all happen when i broke my timing belt. </TD></TR></TABLE>
If you broke the timing belt on your H22a, and the belt broke while you were driving you most likely bent some valves (unless you had them checked!) which would cause you to not have enough compression for the to start period!
Old Apr 30, 2003 | 05:53 PM
97H22's Avatar
Default Re: wtf is wrong w/mycar (AzuleBB1)
i was driving about 35mph in 3gr when the belt borke. 2week later i got the head off and take it the shop to see any bent valves. but was everything was still good and no valves was bent (lucky me). i replace head gasket,water pump and timing belts and than put everything back together and here i am trying to finger out why the car wont start
***my car wont start. when i have the head light on (very dim) and the car wont crank or start, when the light is off the car crank but still no start. has this happen to any one before
Old Apr 30, 2003 | 07:06 PM
Honda318dx's Avatar
My money is the cam timing is off...
Old Apr 30, 2003 | 07:09 PM
Boostless97Lude
Guest
Posts: n/a
Default Re: wtf is wrong w/mycar (Honda318dx)
nah, your muffler bearing is bad, that always happens when it goes. just go to Honda and order yourself a new muffler bearing, install that thing, and your car should just crank right up
Old Apr 30, 2003 | 08:45 PM
Slatelude's Avatar
Default Re: wtf is wrong w/mycar (Boosted97Lude)
boosted.....lol....der!!
I know its blatently obvious but check your ground on your batt/alternator....dumb things happen all the time, and clean your connections on the batt.
Old May 1, 2003 | 05:34 AM
Boostless97Lude
Guest
Posts: n/a
Default Re: wtf is wrong w/mycar (Slatelude)
i more or less agree with corey on this one, if the car turns over, but won't start, i think the timing is off, i just figured that would be funny b/c mostly everyone said tha battery, i just thought i'd toss it up a bit
Old May 1, 2003 | 06:10 AM
Jeff33S's Avatar
you said you broke the t-belt, but nothing was damaged... I dunno how about a compression test?
-Jeff-
Old May 1, 2003 | 09:03 AM
osuPrelude's Avatar
Default Re: wtf is wrong w/mycar (Jeff33S)
Did they do a load test on your battery? From what I understand, typical batteries don't react well to four or more charge cycles, until the battery won't hold a load anymore; yet the battery still had good voltage. This happened to my old truck. The battery lasted 8 years HAHA, but some batteries crap out earlier than others. So make sure you get a load test if u didn't get one. I figured this might help. good luck
Old May 1, 2003 | 09:10 AM
Elkins911's Avatar
Default Re: wtf is wrong w/mycar (osuPrelude)
with dim head lights, its either your battery or your alternator. stop making us guess and just replace the battery.... if it still doesnt start, replace the alternator on that same day.
Scheizty
Jun 7, 2009 05:09 PM
civic=goodgasmileage
Honda Civic (2001 - 2005)
Jul 13, 2008 06:25 PM
DeadLikeMe
Sep 10, 2007 12:53 AM
