Whats the problem with oversized valves and stage 2 cams?
Old Apr 29, 2003 | 06:18 PM
Imadreamer1226's Avatar
Default Whats the problem with oversized valves and stage 2 cams?
My friend recently built up his H22 and thought that oversized valves would be better than stock size. Now he had already purchased skunk2 stage 2's. We already put it all together and the car is just not quick. 14.5s in the 1/4 are pathetic for a fully built head and block. We just saw in small print on the box and it said to not used oversized valves with these cams. WTF????? Any info about why oversize valves cant be used with stage 2 cams would be great.
Old Apr 29, 2003 | 06:24 PM
dfoxengr's Avatar
Default Re: Whats the problem with oversized valves and stage 2 cams? (Imadreamer1226)
cause SK2 says so...
the cams are specifically made for the air flow stock size valves produce. i also think the valve seat is bigger on the ovesized, so that can cause piston clearance probs with the high lift
92JDMCB7
Apr 14, 2009 04:28 PM
isaacprl
17
Feb 6, 2008 10:30 AM
reek
May 11, 2005 09:38 AM
firthy
Jul 28, 2004 10:56 AM
kwik93si
May 1, 2003 07:11 PM
