Auto to Man. Mounts diff or no?
Well technically the left side, front, and rear mount all bolt up to the tranny. So you may need an almost entire set of Manual car mounts.
Honda part numbers are the same for the left and right side. The front and rear are different. Rear mount goes into a diffenent set of holes in the rear cross member.
Take a look for at the part numbers for yourself - http://www.hondaautomotivepart...gry5=
Just change the transmission type to KL4AT for automatic. Under "System\Component" find "Engine Mount"
I think kevin is asking cause he's looking for mounts for me
for further clarification, we're putting a d16y7 in a 90 DX. we're doing a 5spd conversion as well. since we're using the hydro 5spd tranny, i don't need the rear tranny metal bracket
anyway... here's my WTB thread. https://honda-tech.com/zerothread?id=490879
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by limoZeen »</TD></TR><TR><TD CLASS="quote">i just did this swap. the REAR mount (on trans) is different. everythign else is the same. thats it and thats all</TD></TR></TABLE>
You mean you were able to use the automatic tranny ones on your swap. That's good info to know! BUT - technically the front mount and trans bracket are different as well as the rear mount and trans bracket. The part numbers say it all.
emicha1
Honda Civic (2001 - 2005)
Aug 12, 2014 10:10 PM
InTheZoneAC
Mar 31, 2014 08:11 AM
