Codes 9, 16 on zc
Old Apr 29, 2003 | 04:25 PM
typegsr's Avatar
Default Codes 9, 16 on zc
I just finished my zc swap into a dx and i am getting codes 9 and 16. Can someone please help me with this. The car is not running as great as I thought it would be, could the codes be the problem?
Old Apr 29, 2003 | 04:38 PM
FourthGenHatch's Avatar
Default Re: Codes 9, 16 on zc (typegsr)
I have a code 9 in mine also. Thats for the cylinder position sensor I believe. Maybe if we switched the 2 wires on it it would go away or something.
Old Apr 29, 2003 | 05:04 PM
markw's Avatar
Default Re: Codes 9, 16 on zc (FourthGenHatch)
9 is usually the cam angle sensor on the exhaust cam needs the wires swapped. 16 is ignition signal, is the distributor the one that came in the engine, and is it a known good? If not, swap the ignitor module from another one into it. They're all the same DX, Si, ZC, Teg... etc.. It's the little plastic brick with 4 wires inside the distributor. Also, carry a spare and tools to change it, it's a high failure item, even the NEC one...
Old Apr 29, 2003 | 05:13 PM
MONSTERZC's Avatar
Default Re: Codes 9, 16 on zc (markw)
if you have code 9 you have a bad dist amd you need to replace b/c the crank angle senor is bad and it is a pain to which out.
Old Apr 29, 2003 | 05:20 PM
typegsr's Avatar
Default Re: Codes 9, 16 on zc (MONSTERZC)
So should i switch the two wires? or get a new distributor? Can anyone still help me with a code 16.
Old Apr 29, 2003 | 05:41 PM
markw's Avatar
Swap the angle sensor wires, see if it clears the code 9. I think you have issues with wiring right now. Do you have a helms manual?
Old Apr 29, 2003 | 06:02 PM
drjondurst's Avatar
http://www.geocities.com/civiczc/zcwire.html
might help
90si-rex
17
Jul 7, 2011 11:56 AM
XplicitzOldSkoolDA
10
Aug 19, 2008 06:51 PM
Crx-Racer4Life
10
Jul 1, 2004 12:38 PM
VTgringo
Jun 23, 2003 07:28 PM
messeduprex
Apr 19, 2003 10:30 AM
