87 Auto transmission
Old Apr 29, 2003 | 03:56 PM
klaner's Avatar
Default 87 Auto transmission
I just bought an 87 LXi Hatchback. The Tranny thumps when shifted between P, R, and D4. Every accord I test drove in this year range had the same problem in various degrees. Is this normal, or am I in for trouble soon? My guess is that the motor mounts are worn? TIA
Old Apr 29, 2003 | 09:18 PM
jballou's Avatar
Default Re: 87 Auto transmission (klaner)
Shoot, even my 97 accord does that.
Old Apr 30, 2003 | 03:29 AM
klaner's Avatar
Makes me feel a little better, anyone know if the same tranny is found in any other models incase I end up needing a replacement?
Old Apr 30, 2003 | 04:20 AM
Stew Pidasso's Avatar
Default Re: (klaner)
Mine does that too. You might want to change the tranny fluid. I did and it helped...
Old Apr 30, 2003 | 04:38 AM
aktc167's Avatar
Default Re: (Stew Pidasso)
i had my tranny fluid changed last yr and it shifted better, but now im having problems with the parking....its really stiff and tough to shift. how often we have to change tranny fluid for our cars? sry i shoulda posted started a new thread.
Old Apr 30, 2003 | 05:14 AM
carolinaACCORD's Avatar
Default Re: (aktc167)
~75-80K miles depending on how you drive
Old Apr 30, 2003 | 08:37 AM
klaner's Avatar
What fluid should I use. Dexron II I know, but are there better brands tha others? Synthetic Dexron II?
Old Apr 30, 2003 | 08:38 AM
Genuine Honda ATF
Old May 1, 2003 | 12:15 AM
Stripped Honda's Avatar
99-0104
Default Re: (carolinaACCORD)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by carolinaACCORD &raquo;</TD></TR><TR><TD CLASS="quote">~75-80K miles depending on how you drive </TD></TR></TABLE>
you should change the tranny oil every 30,000 miles MAX i change it every 15,000 because there is no filter in honda trannys and if the oil gets too dirty then it helps wear out the clutches early so i figure spending 12.00 for a tranny oil change is cheap comapired to pulling out a tranny and having it rebiult.... and i agree with every one else Honda tranny fluid only
edit: your clunking noise may be a bad motor mount check them out ...
Old May 1, 2003 | 05:57 AM
YeuEmMaiMai's Avatar
Default Re: (Stripped Honda)
a lot of the honda cars do not retart the timing during a shift and it makes the shift appear to be very hard. i believe that it was rectified on 98 and newer cars
Old May 1, 2003 | 08:18 AM
klaner's Avatar
The problem doesn't affect driving shifting, only when initially put into gear.
Old May 1, 2003 | 11:36 AM
problem is that the timing is NOT retarded when you put it in gear either.....
Old May 1, 2003 | 01:04 PM
klaner's Avatar
Ahh, thanks for clarifying.
ragnarok0mega
Aug 1, 2010 06:32 AM
a12rnulfo
Mar 11, 2008 03:48 AM
DaChoZn1
Apr 7, 2004 03:26 PM
DrunkNRacer
May 8, 2003 11:45 AM
