n00b Sus. questions
Old Apr 29, 2003 | 02:41 PM
94HybridEX's Avatar
Default n00b Sus. questions
If you flame me, I can take it....I've been around here long enough...
But here is goes:
What exactly do things like sway bars and strut tower braces do? What does getting longer (or shorter?) sway bars change? Does my car (94 civic ex coupe) come stock with sway bars?
Thanks a lot for any help you can provide me.
Old Apr 30, 2003 | 10:10 AM
94HybridEX's Avatar
Default Re: n00b Sus. questions (94HybridEX)
Anyone want to give a noobie a little help?
Old Apr 30, 2003 | 10:39 AM
P1mpSlap's Avatar
The "anti-sway bar," "stabilizer bar," or even (incorrectly) "roll-bar." It is usually a round bar which connects the left wheel suspension assembly with the right side. It may be found at the front and/or rear. Its main function is to keep both wheels rolling at the same rate when meeting bumps; but it also affects handling. A front anti-roll bar increases understeer and a rear bar increases oversteer.
Charicteristics of such can be defined by the thickness of the bar and how it affects handling.
Strut tower bars increase chasis rigidity and flex.
Old Apr 30, 2003 | 11:17 AM
RangerDan's Avatar
Default Re: n00b Sus. questions (P1mpSlap)
I have used a couple different set-ups and strut bars do make a difference...although i havent felt much diff. in the pricey ones and the 20.00 ones.
Get one for the upper front and feel the diff. its there. Put when on my eg a couple years ago (car has been since) and the wife drove it without knowledge of the bar...Anyways when she got home she comments on how much nicer the car handled. And performance aint her thing.
I usually run upper front, upper rear, and lower rear strut bars and a sway bar in the lower front.
Old Apr 30, 2003 | 11:22 AM
CXHatchback's Avatar
Default Re: n00b Sus. questions (RangerDan)
Your 94 ex comes with a stock front swaybar (21mm?)
And you don't get longer or shorter bars, you get thicker ones. 21mm is the diameter.
Old Apr 30, 2003 | 12:11 PM
94HybridEX's Avatar
Default Re: n00b Sus. questions (CXHatchback)
Thanks for all the help, I've learned a lot.
What brands sway bars do people usually run (or doesn't it matter)? Is it worth it to get cheapy's off eBay. The same applies for the strut tower bars, I've seen a lot on eBay...are they o.k.?
Old Apr 30, 2003 | 12:55 PM
RangerDan's Avatar
As strut bars go I think the ones on ebay are ok.
Thers a diy on strut bars floating around on one of these forums right now.
Old Apr 30, 2003 | 01:07 PM
94HybridEX's Avatar
I read that one, and that's what prompted this topic.
That one looks like a ton of work that I'd rather not do.
raffydogg
Jul 15, 2008 02:04 PM
WhiteRice02
Jul 16, 2006 01:20 PM
fluke83
Jul 6, 2004 03:13 AM
B_CRUZ!
22
Jun 26, 2002 03:25 PM
