is this the right spark plug # for ngk coppers
Old Apr 29, 2003 | 01:33 PM
Shark Tank's Avatar
Default is this the right spark plug # for ngk coppers
i have 12.4:1 compression and usually run a 7 heat range plug...is this the right ngk part number for the copper plug
NGK BKR7ES-11 (2387)
Old Apr 29, 2003 | 01:41 PM
sgT's Avatar
sgT
Default Re: is this the right spark plug # for ngk coppers (Shark Tank)
i wouldnt use copper personally.
Old Apr 29, 2003 | 01:45 PM
baonest1's Avatar
Default Re: is this the right spark plug # for ngk coppers (sgT)
i use the platinums. $40 for a set. but they come with a 1 year warrantee. when i first stared my motor. i was running riiiiiiiich as yell. so after about 3 weeks of running, the car wouldnt start. plugs were black as hell. got a free set. advance was pretty pissed. but it was under warantee.
Old Apr 29, 2003 | 02:07 PM
Shark Tank's Avatar
Default Re: is this the right spark plug # for ngk coppers (baonest)
cool, i guess you suggest the platinum ones steve...the pfr7g-11 or the bkr7evx-11? both are made of platinum but the pfr ones are more and are a true platinum i guess.
does advance or any parts store stock any plugs in the 7 heat range?
Old Apr 29, 2003 | 05:28 PM
sgT's Avatar
sgT
BKR7EVX11 are platinum coated copper apparently.
but they have been discontinued and replaced with an iridium part.
Old Apr 29, 2003 | 06:04 PM
baonest1's Avatar
about storing pluts with heat ranges i dont know. never asked them. they dont cary plugs like NGK plat. in stock depending on where you are at. they order most of them, so im sure you can request heat 7 plugs
Old Apr 29, 2003 | 06:06 PM
Nameless RB26's Avatar
My local Shucks special orders PFR7G-11's for like 21$ a piece.
Edit: So I wouldn't recommend getting them from an automotive store.
I've seen them on the web for 10$. Good plugs though.
Old Apr 29, 2003 | 06:39 PM
Tommy_Gunns's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sgT &raquo;</TD></TR><TR><TD CLASS="quote">BKR7EVX11 are platinum coated copper apparently.
but they have been discontinued and replaced with an iridium part.</TD></TR></TABLE>
Nooooooooooooooo...discontinued, why? Such a good cheap alternative to the stock platinums.
Old Apr 29, 2003 | 06:43 PM
Shark Tank's Avatar
Default Re: is this the right spark plug # for ngk coppers (Tommy_Gunns)
clubplug.net and monarch still have them listed on their sites. so i order like 20 of them...just cant justify spending 10-11 per plug
ScottF
Feb 21, 2010 10:49 AM
123Four
Sep 22, 2007 03:28 PM
Aeka GSR
Dec 5, 2003 10:14 AM
reefer_bob
Jul 22, 2002 12:32 PM
mattmw88
Feb 22, 2002 07:54 AM
