HID electrical q's
Old Apr 29, 2003 | 11:08 AM
d8168055's Avatar
Default HID electrical q's
does it require more voltage to start them up? how about when they are in use? thanks...
Old Apr 29, 2003 | 11:12 AM
Ideal R's Avatar
New User
Default Re: HID electrical q's (d8168055)
I think they use more voltage to start up, but once started I think they use less.
Dont' quote me on that, please correct me if I am wrong.
Old Apr 29, 2003 | 11:16 AM
Dave-ROR's Avatar
Default Re: HID electrical q's (Ideal R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ideal R &raquo;</TD></TR><TR><TD CLASS="quote">I think they use more voltage to start up, but once started I think they use less.
Dont' quote me on that, please correct me if I am wrong.</TD></TR></TABLE>
they take more power at startup but consume less afterwards. More amps, not sure about voltage..
yellow blur's Avatar
The initial draw is pretty substantial but they do require less voltage than stock halogens.
Old Apr 29, 2003 | 02:07 PM
Trevor(Toronto)'s Avatar
Initially, when the system is started, the ballast produces pulse voltages ranging between 18-20kilovolts and these pulses continually cycle until the arc is established.
Old Apr 29, 2003 | 08:07 PM
t's Avatar
t
Amperage, not voltage.
Old Apr 29, 2003 | 10:15 PM
uNF$@#!'s Avatar
Default Re: HID electrical q's (dawhiteboy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dawhiteboy &raquo;</TD></TR><TR><TD CLASS="quote">
they take more power at startup but consume less afterwards. More amps, not sure about voltage..</TD></TR></TABLE>
voltage shouldnt vary. I dont think that wouldnt work well in a 12vdc circuit
considering v=ir, current should remain the same. the initial "boost" you see at the initial warm up is from the ballasts charging. (capacitor discharging).
then again, i'm the guy at the expo who was wondering why the cigarette lighter wasnt working....looking at wrong fuse
Old Apr 30, 2003 | 08:23 PM
t's Avatar
t
Default Re: HID electrical q's (Soup ****)
Voltage does vary. 12-14.6 volts
Considering E=IR (Not V=IR), E=voltage I=amps/current R=resistance
Voltage should be 14.4 volts with the motor running.
Resistance of the ballast does not change.
Current(amperage) draw will be higher (at startup)
Current does not remain the same, hence the reason most hid kits tell you to put in a higher amp fuse.
361 accord
Jul 24, 2008 01:39 PM
BJA86
Audio / Security / Video
23
Nov 11, 2007 04:01 PM
mikeunreal2
16
Sep 13, 2006 04:57 AM
elpiar
Apr 6, 2005 10:09 PM
boosted_zc
Oct 23, 2004 08:17 PM
