B16a Manual trans fluid,,,how much????
get under the car and look at the tranny. There's a fill hole, pretty much a bolt type deal like an oil drain plug, about 1/2 way up the trans. There's your fill hole, fill it up untill the fluid just starts to come out that hole. The drain hole is the plug near the bottom of the trans.
Hope that helps
Hope that helps
if you don't have a hose to snake into that little sideways hole... you can undo the one bolt that holds the speedo sensor in on the top if the tranny and stick a funnel in there... I think the amount rec. is 2.0-2.5... somebody correct me please
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ThaSpitefulWun »</TD></TR><TR><TD CLASS="quote">if you don't have a hose to snake into that little sideways hole... you can undo the one bolt that holds the speedo sensor in on the top if the tranny and stick a funnel in there... I think the amount rec. is 2.0-2.5... somebody correct me please</TD></TR></TABLE>
On my trans there is a bolt on top I used, I did not even mess with the speedo sensor.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by raene »</TD></TR><TR><TD CLASS="quote">Wow, cool info! Hopefully I can throw away that ghetto funnel rig I've got set up now!</TD></TR></TABLE>
lol, we probably made the same thing almost, I used a straw from one of those old squirt bottles then I used a water bottle for the funnel. Then I went to autozone and actually saw they had them for sale. Oh well
actually its like about 2 qts if you put too much it will just smoke untill the excess is burnt out i have had about 4 cars all with b series swaps and always used about 2 qts........and the place to fill it is right behind the cv joint there is a 17mm bolt undo that and make a funnel to fit in there and fill it that way.......or the speedo cable theory works too..........
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kincaidcrxsi »</TD></TR><TR><TD CLASS="quote">2.2 quarts</TD></TR></TABLE>
thats right.. just fill to the top
Damon Reeves
Apr 15, 2007 09:11 AM
Hond@
Nov 11, 2006 04:45 PM
