Shifter Bushing Question
I forgot more about hondas then you will ever know....
From: hop,skip, and a jump from the city,, new friggin york, USA
do you have the metal B&M kit? if so, the shifter rattle would be vibration transferred from the bushing. if you ahve the standard energy type bushing, then you might have something loose. good luck.
Honestly, I do not know what brand bushings I have. It came with the car and it was rattling when I bought it. I just got off my lazy butt to do something about it. At first I thought it was perhaps the bushing on the transmission side. But that was all replaced and retightened when I got my new transmission. I still have factory shift rod. Also, would engine bushings amplify the vibration by much?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CACK ***! »</TD></TR><TR><TD CLASS="quote">Call Baranco they can probably get you new shifter bushings
lol</TD></TR></TABLE>
You know, you should seriously look into becoming a comedian.
lol</TD></TR></TABLE>You know, you should seriously look into becoming a comedian.
len, I have the same problem you do, and my shifter rattles like a **** when decelerating and cruising.. I've pin pointed the problem to that bushing at the end of the shift rod (its the B&M one that i have)... lol, as a matter of fact I was about to call YOU tomorow to get one.. lol
After I installed my Energy Suspension bushings there has been a rattle in my shifter at high rpms~7500-8000. ES bushings are red, BTW.
I recently changed the back shifter bushing (rectangular looking one) back to the stock rubber bushing. It has helped, but not all of the buzzing is gone. I'll most likelywill try changing the front round one back to stock to see if this eliminates the rattle completely. Prior to me installing the ES bushings, the stock stuff did not let the shifter rattle.
The rattling is a common problem with people who have changed to harder bushings. I've heard that Mugen shifter bushings do not rattle and I may be trying that if I can't stand the stock stuff once I get that in.
HTH
HTH
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kkim »</TD></TR><TR><TD CLASS="quote">After I installed my Energy Suspension bushings there has been a rattle in my shifter at high rpms~7500-8000. ES bushings are red, BTW.
HTH</TD></TR></TABLE>
I have the same bushing, no rattle here. Torque it to 16lbs j00.
hmmm... that's interesting. I did torque the bolts to whatever the Helms listed for the stock bushings. can't remember... is 16 what the stocks are?
serious rattle/vibration at 8k w/ ES bushings.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kkim »</TD></TR><TR><TD CLASS="quote"> ES bushings are red, BTW. </TD></TR></TABLE>
They come in black too.
My C's DPS with ES bushings rattles alot.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tweakmeister »</TD></TR><TR><TD CLASS="quote">probably your cat heatshields and it just feels like the shifter.
eh, could be the shifter, okay
I'm definitely going to take the remainder of that off tomorrow to see if it helps.
</TD></TR></TABLE>I'm definitely going to take the remainder of that off tomorrow to see if it helps.
Why change the bushings at all? Just because its a $12 mod doesn't mean its effective. I don't see how "more vibration" translates into more performance...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jabroni95gsr »</TD></TR><TR><TD CLASS="quote">Why change the bushings at all? Just because its a $12 mod doesn't mean its effective. I don't see how "more vibration" translates into more performance...</TD></TR></TABLE>
The vibration is a side effect. When I had my stock shifter, I noticed improved feel, and more precise shifts. Definatly worth every penny.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dr Pooface »</TD></TR><TR><TD CLASS="quote">
The vibration is a side effect. When I had my stock shifter, I noticed improved feel, and more precise shifts. Definatly worth every penny.</TD></TR></TABLE>
This may be so...but given that the itr shifts are already razor sharp, i wouldn't trade a little more feel for annoying buzzes and vibrations IMO.
