bill gude race package
Old Apr 29, 2003 | 05:45 AM
redteg's Avatar
Default bill gude race package
has anyone heard anything good bad or performance wise about the gude race package. i just sent it out to him and i am looking to see what i can expect from it. i sent him my head manifold and throttle body. it s an 1998 ls. according to him i will make about 200-205 horse. any info will be appreciated.
Old Apr 29, 2003 | 06:00 AM
4g4me's Avatar
Default Re: bill gude race package (redteg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redteg &raquo;</TD></TR><TR><TD CLASS="quote">it s an 1998 ls. according to him i will make about 200-205 horse. any info will be appreciated.</TD></TR></TABLE>
wow I am sure an ls motor doesnt put anything more than 125 hp to the wheels stock. IF he is claiming 205hp from your ls, then damn thats a serious increse. This will not do well here.
Good luck to you though!
Old Apr 29, 2003 | 06:03 AM
VTECorona's Avatar
Default Re: bill gude race package (4g4me)
Thats a serious increase man, did he give you details on what exactly is going to be done?
Old Apr 29, 2003 | 06:06 AM
redteg's Avatar
Default Re: bill gude race package (97RedTegGSR)
he is going to shave the head to bump compression to 11.1 port polish cams larger valves and sprigs also bore out the manifold and throttle body
Old Apr 29, 2003 | 06:11 AM
VTECorona's Avatar
Did he rate you 200-205 at the flywheel or wheels? Even at the flywheels that is a huge increase for those mods.
Old Apr 29, 2003 | 06:57 AM
dip-set's Avatar
let me know how it turns out..what did he price u on that work...my ls needs a foot in the ***...
Old Apr 29, 2003 | 08:02 AM
Project X's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redteg &raquo;</TD></TR><TR><TD CLASS="quote">has anyone heard anything good bad or performance wise about the gude race package. i just sent it out to him and i am looking to see what i can expect from it. i sent him my head manifold and throttle body. it s an 1998 ls. according to him i will make about 200-205 horse. any info will be appreciated.</TD></TR></TABLE>
If it's 200-205 hp, then it's about 165-170 whp. That is possible provided that everything is built. I assume it's N/A, so you need high comp. pistons, race P&P, big intake, header, exhaust, racing cat, TB, IM, cams, valves, ECU tuned, etc.
Old Apr 29, 2003 | 09:36 AM
delslow94's Avatar
all i gotta say is look at the dyno charts online where gude tells how they increase wheel hp by 40-60 hp on a gsr. look closely at the numbers on the graph. his baseline is 127whp on a gsr. now thats extremely low number. its even low for a b16 so choose wisely i truly havent heard many good things about them like how they recondition damaged heads and sell them if their packages. it might be ok for some but i dont like repaired items. plus milling a head for higher compression isnt my thing since u cant undo milling.
Old Apr 29, 2003 | 09:41 AM
SlowPoke's Avatar
New User
Default Re: bill gude race package (delslow94)
Yea not to bash on Gude, but I have'nt heard the best things about him, although some people like him. Personally I would'nt ever mill the head, its the cheap way out, plus it throws off your timing marks
Old Apr 30, 2003 | 10:16 AM
redteg's Avatar
Default Re: bill gude race package (SlowPoke)
my main concern with this is that i don't blow the motor. especially the bottom end. thats why im not going to change the redline. will his package hurt or blow my motor up. usually blowing up an na motor is due to human error or just plain stupidity. need info
Old Apr 30, 2003 | 11:41 AM
ITRfaithful's Avatar
how come some people here don't recommend milling? does milling do anything else beside raise compression?
Old Apr 30, 2003 | 01:18 PM
UNCVLZD's Avatar
My friend had a Gude build on a D16Z6 ('92 SOHC VTEC Si). Don't get it! Everything's been disasterous since he got it back. The timing was never right, and couldn't be set right. The cams were manufactured wrong. The valves collided with the pistons at around 5,000rpm's. It's a huge P.O.S. now. To top it off, Gude basically told him he's screwed. They had their money already, they didn't care. **** em! (Can I say that?)
Old Apr 30, 2003 | 02:30 PM
RABBIT9's Avatar
Default Re: (mattoien)
I was interested in one of the Gude packages myself, but instead of taking the plunge, I just bought a TB from them to see the kind of work they do. The workmanship was shitty at best, and they installed the throttle cams incorrectly. My shop had to straighten the **** out which cost them time and me money. It saved me money in the long run though, because I researched there reputation on several boards (which agreed with my own experience), and I knew not to buy anything else from them.
Old Apr 30, 2003 | 06:08 PM
delslow94's Avatar
Default Re: bill gude race package (iloveintegras)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iloveintegras &raquo;</TD></TR><TR><TD CLASS="quote">how come some people here don't recommend milling? does milling do anything else beside raise compression?</TD></TR></TABLE>
it raises compression yet it also screws up timing and it can never be unmilled if you want to lower compression again. if your head warps it makes it hard to remill the head to make it flat.
93LS
Mar 13, 2008 08:04 PM
tippatone
Oct 2, 2007 02:38 PM
myke
26
Jun 8, 2007 12:30 AM
ek9 ferio
10
Feb 16, 2006 07:59 PM
B20b4door
Aug 16, 2004 05:10 PM
