fitting the jdm 4-1 header....
the time has come, i'm about ready to get the jdm 4-1 header, but i need to know how much i need to take off of the crossmember in order for it to fit.
here's a couple of pix of how I cut my crossmembers to fit the jdm 4-1 header...still a tight fit. Used it for a few months and bought a placeracing crossmember instead.
how is your clearance with the PR x-member? and was it worth getting or do you wish you had a JimFab or Z10 x-member now (for caster adjustment)?
I just needed something better than the hammered down crossmember so performance is not really an issue. Fitment is excellent and value ($190) is very reasonable. Handling improved considerably (more stable) especially on high speeds. I still have some wheel hop but slightly reduced.
just asking but did you re-enforce your crossmember at all or did you just cut and weld? I've heard that when you just take a chunk out of your crossmember like that you'll end up tweeking the chassis more when you hit a hard bump pn the road.....anyone ever had this problem?
i'm trying to put mine on my b18b right now and i cut the lip off the cross member. That wasn't nearly enough. You guys pull it up from the bottom or through the top when installing?
From: hittin corners so hard you can taste my rims..
on mine, i just cut it back maybe half, to a full inch.. and it worked out.. but once i get mine out of the paint shop, im planning on going PR too.. but, whenever i wanted to take the header out, i always had to pull the X member out..
shiet...i can't believe this post is still alive...i made it so long ago...but i'm gonna try n' take some pics soon, and show the clearance on my car. i have the skid plate too, so that kinda takes about 1/2 inch off clearance
heh.. yeah, i dug it up.. lol
lower skid plate.. never really got the conpect of that.. they call it heat shild.. but, its on the outer ground side of the header, and well.. no one see's it.. basicly a 60 buck waste to me.. but pics are always good man.. lets see it.
i got a b16 in my 90 hatch, i had to notch out the X-member a good 1 and a half inches and took steel and welded it back in where i cut it out so it was reinforced then i took a 1/4 plate steel in like a square kind of form and welded it to the bottom of the cross member for stability, i know it sounds wierd but i will try to get some pics soon lol
fastest
May 8, 2004 07:13 AM
