Im stumped. Valve question here
Old Apr 28, 2003 | 10:24 PM
DIRep972's Avatar
Smarter than you
Default Im stumped. Valve question here
Alright guys,
I am making this post hoping that I get lucky and someone reading this could have had the same experience as me or similar.
To make a long story short, my timing belt slipped while I was hand rotating the crank. Valves made contact with pistons but I took my chances and assembled the motor anyways, hoping it didnt do any damage.
I assembled everything and adjusted the valves. When I started the motor it made a loud ticking noise from the head. Similar to the sound of very loose valves, but also close to the sound of a bent valve. The ticking gets more constant as rpm goes up but doesn't really get louder.
My first thought was bent valves. So i did a leak down test and leak down came out almost perfect, only 2% leak in each cyl. Comp. is 180-190 accross too on a stock LS.
I know this is one of those questions that is extemely vague but I am kinda looking for anything right now as I am stumped as to what the sound could be. could valves be bent and still put out such good #'s? any parts on the head I can inspect that might cause it to make that noise? at this point I am open to any suggestions. thanks guys
chris
Old Apr 29, 2003 | 08:10 AM
DIRep972's Avatar
Smarter than you
Default Re: Im stumped. Valve question here (IRepD)
I was up late worried last night thinking it could be a spun bearing. anyone?
Old Apr 29, 2003 | 09:02 AM
boostin b16's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IRepD &raquo;</TD></TR><TR><TD CLASS="quote">I was up late worried last night thinking it could be a spun bearing. anyone?</TD></TR></TABLE>
i seriously doubt you spun a bearing! tell us more about the noise .. is it a hard knocking/thumping or more of a metalic tapping? have you done a valve adjustment yet? if i were you i would do a valve adjustment and another leakdown. it that offers no conclusion then try pulling the head and looking it over. hope you figure it out!
Old Apr 29, 2003 | 09:18 AM
raene's Avatar
This might be too obvious, but are you sure it isn't just the fuel injectors?
Old Apr 29, 2003 | 09:20 AM
TEAMGENDAI's Avatar
adjust your valves to .007 on the intake and .009 exhaust good luck tiger
Old Apr 29, 2003 | 10:30 AM
ChiBoy's Avatar
Are the LMA's ok?
Old Apr 29, 2003 | 12:18 PM
DIRep972's Avatar
Smarter than you
Default Re: (ChiBoy)
boostinb16, the noise is a high pitched ticking. Sounds like very badly adjusted valves. Gets more consistant w/ rpm but I would not say much louder. I don't think its a bearing either the motor still idles normal, doesnt stumble or anything @ idle. I havn't driven it yet though. I adjusted the valves to .007ex/.004in but I am going to do it again tonight just to make sure.
raene, Its not the injectors. Definitly in the head. my old stock injectors used to tick so i know the sound.
Teamgendai, i will give that a shot tonight. what would having looser clearances do?
Modified by IRepD at 5:35 PM 4/29/2003
Old Apr 30, 2003 | 12:06 PM
JimBlake's Avatar
Default Re: (Mr. Belding)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr. Belding &raquo;</TD></TR><TR><TD CLASS="quote">... what would having looser clearances do?...</TD></TR></TABLE>
Why did you adjust them so tight? I think he just meant for you to adjust them to spec. Or... what's the clearance supposed to be for your engine?
Old Apr 30, 2003 | 12:12 PM
DIRep972's Avatar
Smarter than you
Default Re: (JimBlake)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JimBlake &raquo;</TD></TR><TR><TD CLASS="quote">
I adjusted them to spec, .007ex/.004in is spec on an LS motor. The motor was definitly cold but I gonna redo it tonight just to make sure I did it right.
Old May 1, 2003 | 11:46 AM
DIRep972's Avatar
Smarter than you
Default Re: Im stumped. Valve question here (Mr. Belding)
Well it turns out I am just a slacker and did a crappy valve adjustment the first time. lol. I went back through and redid all the ones I didn't like and the car idles smooth as hell right now. I think I was just paranoid. Its always the simplest thing. Anyways, car is back together and running good thanks for the help guys. oh yeh, .004/.007 is spec for an LS motor. later
Old May 1, 2003 | 05:14 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr. Belding &raquo;</TD></TR><TR><TD CLASS="quote">Well it turns out I am just a slacker and did a crappy valve adjustment the first time. lol. I went back through and redid all the ones I didn't like and the car idles smooth as hell right now. I think I was just paranoid. Its always the simplest thing. Anyways, car is back together and running good thanks for the help guys. oh yeh, .004/.007 is spec for an LS motor. later</TD></TR></TABLE>
very very glad to hear the good news!! i kinda figured it was a valve adjustment! i have seen a car that would not even start after a rebuild because of impropper valve adjustment!!
way to go mr. B!!
b20integrapower
Feb 9, 2006 07:12 PM
alpha_1
Apr 20, 2004 12:02 PM
rlj51
Apr 9, 2003 01:48 PM
onyx00
Feb 24, 2002 01:32 PM
