Koni Yellow Shock Install Help Please
I bought a set of Koni Yellow shocks for 94 RS Integra. Everything was going smoothly installing untill I noticed the the medel cylinder the bushings go around is not large enough for the shaft to go thru. This is at the very top of the shock tower. Does anyone know where I buy the right part? Thanks
Normally with Konis you need an adaptor. Check with http://www.Tornactive.com he should have them in stock for like 45.00 bucks (please dont quote me on that)
I think you are talking about the strut dust cover.
The hole needs to be opened up to 12mm (1/2" or so) to allow the Koni piston rod to go through. It is easy to do, a drill press makes thing safer/easier but a hand drill and vise would work fine.
Or if you mean #12 (the spacer bushing) it should have come with the Koni's
#10 in the pic below
Modified by SLPR at 11:04 AM 4/29/2003
3rdgen3
Suspension & Brakes
13
Jan 26, 2011 09:24 PM
Solo2Vtec
Apr 26, 2003 05:24 AM
DevinW
May 7, 2002 05:27 PM
