how do u take this off?
Old Apr 28, 2003 | 05:29 PM
91hatchcivic's Avatar
Default how do u take this off?
i was taking off my passenger door pannel and the only thing i cant figure out is the cranks for the window,,, how do i get them off?
Old Apr 28, 2003 | 05:35 PM
Neukin's Avatar
Default Re: how do u take this off? (91hatchcivic)
if you mean you cant get the cranks off all you do is get a old t-shirt or like fabric i guess and get it between the plastic handle and that little plasic washer lookin thing it. (you got the handle then the plasic washer thing and then the panel. move the rag back and forth until you get the c-clip to fall out. for it to work out right get the handle pointing upwards and then get the rag between there. with the rag on top.
Old Apr 28, 2003 | 05:36 PM
Outsane's Avatar
turn it so the **** if pointed up pull at is slightly and you should see a nickle plated clip (golden color). Get a some kind of a small hook (Dental tools are the greatest for this) and pull on the clip. Don't pull too hard you you may loose the clip.
Old Apr 28, 2003 | 06:43 PM
FourthGenHatch's Avatar
Default Re: how do u take this off? (Outsane)
Go buy yourself a Pick Tool set at Sears, use the Hook pick to pop that bastard out, I can do it in like 2 seconds with my tool. They also come in handy for SOOOOOOOO many things, I pick tools.
Old Apr 29, 2003 | 06:35 AM
Default Re: how do u take this off? (FourthGenHatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FourthGenHatch &raquo;</TD></TR><TR><TD CLASS="quote">Go buy yourself a Pick Tool set at Sears, use the Hook pick to pop that bastard out, I can do it in like 2 seconds with my tool. They also come in handy for SOOOOOOOO many things, I pick tools.</TD></TR></TABLE>
hey fourthgenhatch,,, could you come by my house some day soon so i can replace my broken window??? i live in reisterstown, not that far from you. PLEASE HELP ME!!
Old Apr 29, 2003 | 06:46 AM
Louie B.'s Avatar
OR you could get a window crank tool. (the tool that's accually designed for the job) You can get one at any auto parts store and they're relatively cheap.
Be very careful when popping that clip out, they like to go flying!!! and they're really hard to find when they hit the ground. wrapping a rag around the crank is a good idea to catch the clip.
Old Apr 29, 2003 | 07:01 AM
Shawn C's Avatar
In The Garage
**** that damn tool, it scratches up everything, and you lose the clip 95% of the time. just, as earlier stated, use a rag or old t-shirt, stickit in there, and pull it from side-to-side. it works perfectly 100% of the time, and it catches the clip.
Old Apr 29, 2003 | 08:03 AM
Default Re: (22lbGS-R)
i tried getting a piece of fabric in that small *** smace, i dont know about anyone else, but i finally got a piece of a t-shirt in the space, but it wouldnt work for me. I couldnt slide it back and forth like you guys said , i dont get it, its a tiny crack!
Old Apr 29, 2003 | 08:36 AM
spiceisler's Avatar
Default Re: (91hatchcivic)
Simple! Get a wire hanger and make a small 90degree bend on one side. If you rotate the window crank you'll see a slot which will enable you to see the clip. Just slide the wire hanger in that slot then hook the clip and just lift it off. Don't jerk it!
Your best bet though is the "pick tool" set from Sears like someone else said.
Old Apr 29, 2003 | 07:41 PM
Louie B.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 22lbGS-R &raquo;</TD></TR><TR><TD CLASS="quote">**** that damn tool, it scratches up everything, and you lose the clip 95% of the time. just, as earlier stated, use a rag or old t-shirt, stickit in there, and pull it from side-to-side. it works perfectly 100% of the time, and it catches the clip.</TD></TR></TABLE>
You must not know how to use the tool right, I pull 2-4 cranks a day off of all different makes and models of cars, and I've never scratched a one. And yes, when I first started out, I had a couple of clips go flying, but clips are cheap at any auto parts store and once you get the hang of it you'll learn how to catch the clip with your free hand.
After seeing first hand the kind of damage that can be done by "do it yourselfers" trying to use a pick or screwdriver, I would never use anything but the right tool for the job.
Old Apr 29, 2003 | 07:46 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91hatchcivic &raquo;</TD></TR><TR><TD CLASS="quote">
hey fourthgenhatch,,, could you come by my house some day soon so i can replace my broken window??? i live in reisterstown, not that far from you. PLEASE HELP ME!! </TD></TR></TABLE>
Maybe, but it ain't that hard. Just take off the door panel and undo 2 bolts on the window support thingy, lift out the old glass (or vacuum it up in my case when I did this ), and put in the new one same as reverse. But if you are really stuck perhaps I can help a brotha out.
Old Apr 29, 2003 | 07:48 PM
uszcrx's Avatar
My **** musta been loose because i just pushed in the interior and used a screw driver came off nice an easy
Old Apr 29, 2003 | 09:14 PM
FullMetalJacket's Avatar
Default Re: how do u take this off? (uszcrx)
Use the right tool like the one guy said. I got one in like 96 and used it on every car ive owned..never scratched anything with the right tool. Used it on GM's, Fords,Hondas cars from 1970-1994..realhandy tool..wouldnt not have one in my craftsman box
92egSnatch
Mar 1, 2008 04:10 PM
Xanok
Nov 30, 2007 08:42 PM
civicrtype2
Mar 5, 2005 11:54 PM
TrAnCeD_RaCeR
Mar 17, 2004 01:55 PM
crx_ef8
Feb 1, 2003 10:38 PM
